Tyre Pressure & Traction Control Warning lights Hi Gents
Been doing loads of research and still can't find an answer...
Got new rear breaks at the weekend, picked Colin (the Mrs named him...) up and did a excitable shake down run, all was great... Then we went out in the afternoon and the tyre pressure warning light came on with the tractions control warning light.
I've checked the tyres, yes they were low... VERY low, but now sorted. Tried to reset the sensor with the usual trick but sadly no joy.
After doing some research i'm starting to think its a sensor issue... its a 52 plate and just had the ball joints, brake pipes, disks and pads so i'm hoping its just a loose sensor, but any advice would be greatly appreciated (even its is link to another post).
Thanks folks |
