I screwd up - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Feb 13th, 2013, 11:20 PM
Local Time: 04:39 PM
I screwd up
Damn it did i screw up...changed my oem 17" wheels and runflats for 18S and 215/35/18 I should have got 215/45/18,now there's about a 3" gap from the tire to the wheel arch makes the wheels look like 16s.
So do i lower the car or suck it up and buy more new tires??...Man i am pised
Sorry guys had to vent somewhere.
Im from the UK i just work in the US
Old Feb 14th, 2013, 12:24 AM
Caveman's Avatar
Local Time: 06:39 PM
Your wheel gap has only increased by a little over 4 mm.
You certainly don't want to buy 215/45-18 tires. Standard fitment is 205/40-18.
Old Feb 14th, 2013, 12:37 AM
Im not that well versed on wheel and tyer packages (thats why i probably screwed up)...So would 215/45/18 be to big ?
Old Feb 14th, 2013, 07:59 AM
Local Time: 05:39 PM
Using tyres sizes other than the standard recommended sizes by MINI will mess up the accuracy of your speedo reading for one and also gear ratios to some extent too.
And maybe clearances tyre to inner arch especially on full steering lock where it could/might rub on the inner arch.
Old Feb 14th, 2013, 11:43 AM
mab01uk's Avatar
As width goes up you drop down on wall height to compensate and keep the same or similar width to height ratio.
eg. I use 215/40 x 17 normal tyres instead of 205/45 x 17 run flats, hardly any difference on diameter.
Use a simple online tyre/tire calculator to check and compare sizes:
Tyre Size Calculator - Changing Tyres - Etyres
Old Feb 14th, 2013, 03:20 PM
Caveman's Avatar
Yes ... way too big.
As I said standard fitment for 18" OEM wheels is 205/40-18. Depending on wheel offset and suspension set up you may be able to run 215/40-18.
Old Feb 14th, 2013, 03:43 PM
Online
205/35/18 are killers ! Harshest ride ever
Old Feb 14th, 2013, 05:00 PM
Cooper S Jon's Avatar
i'm running 215/40/18 there fine..
Old Feb 14th, 2013, 09:15 PM
dosent seem like a lot of choice when buying 205/40/18...yeah forgot about speedo calibration...starting to wish i kept the oem's
Old Feb 15th, 2013, 05:07 AM
MINI's are BANG TIDY
Can agree with that. I have 215 35 18s and its like driving with no tyres on some surfaces...bloody awful....but when driving quickly lots of feedback and decent handling
Sent from AutoGuide.com App
