Winter Tyres -Vague Handling on Dry Road - MINI Cooper Forum
Go Back   MINI Cooper Forum > MINI Technical Forums > Wheels, Tyres & Brakes
Sponsored by:
Old Dec 17th, 2013, 07:44 PM
Local Time: 01:40 PM
Question Winter Tyres -Vague Handling on Dry Road
(JCW) Just bought a set of Nokian WR A3 Winter tyres for my 17" wheels.
These are non run flat, and I chose the brand, as they have very good reviews on many tests.
My first impressions driving on cold dry roads, is that the steering above speeds of 60mph feels vague. The tyres feel quite soft and "squidgy" when accelerating, and the car feels it wants to wander left and right.
I'm not sure if this is because I have been used to driving with the stiffer run flat summer tyres, but I don't like the handling at all with these Nokians.
Tyre pressures are 2.5bar.
I'm sure these are great in the snow, but wondering now if I should have perhaps gone for the run flat version.
I had Goodyear ultragrip winters on a previous car, and the handling at higher speeds wasn't an issue then.
Has anyone experienced the same ??
Old Dec 17th, 2013, 07:59 PM
Winter tyres
I was looking to get the tyres you had however i chose Dunlop wintersport M3 instead, only cos of cost.
my initial thoughts was that the drive feels strange.
they seem to slip and slide (however the sliding isn't scary) but if you carry on putting the power down gradually it will stop skidding and grip in the road and instantly go into the direction you want to.
i had goodyear eagle f1 asymmetric 2 before and they just gripped instantly.
but these winter tyres are wobly (maybe due to its size aswell 205/55/16), im just waiting to see how they are in the snow. (if there is any)
Old Dec 17th, 2013, 10:02 PM
Local Time: 02:40 PM
United Kingdom View AMAUTOS7's Classified Ads
Had the Porsche carerra S last year for the weekend and drove it around on winter tyres
It didnt feel vague or anything just gripped like a normal tyre
Have you checked what pressure they need to be at?
How worn are the tyres?
Some tyres need to be run in to get rid of moulding outer layer which should take about 300 miles
Old Dec 18th, 2013, 03:47 PM
I think you are describing the difference between runflat and non-runflat tyres. I've tried several makes of winters (including Nokian WRs), though none of them runflats, and not found any of them vague in a straight line.
The time the winters do feel very slidey is on wet (ie, not icy/snowy) roundabouts when they behave more like an old-fashioned tyre - they start to slide at maybe 60-70% of maximum grip and can be driven in a continuous slide, though that makes me worry about tyre wear. The same is true with dry cornering though then the fear of accelerated tyre wear definitely stops me hooning.
Old Dec 19th, 2013, 01:30 PM
Well, I contacted Nokian about this, and they say that there should be 0.2 - 0.3 bar (up to 4.3psi) higher pressure than summer pressures, and that "in some cases should be even higher, to get stability to acceptable level"
I'm not sure about this, as I mentioned earlier, my previous "performance" car didn't give this type of feedback with winters on. (225x45x18)
I'll increase the tyre pressure, and see.
I think next time, I might plum for the more rigid run flat winter tyres, but again, my previous car had standard tyres.......
Old Dec 19th, 2013, 10:49 PM
Glad someone else has this! My winter car is a mk1 focus, with Hankook winter tyres on it's prone to a 'floaty' feel, i put this down to the small tread blocks that can move around to generate heat, my summer tyre are yokohama prada's which are *much* firmer but when it gets cold they are pretty scary :S
Old Jan 15th, 2014, 03:58 PM
Local Time: 09:40 AM
all winter tires are softer, thats why they work beside different tread pattern. bridgestone blizzak the best rated in ice NO studs is the softest, fastest wearing winter tire. i always ran michelin's, good all around. when thread was down i would use them up in summer until gone, not bad buts a premium tire!
» Recent Threads
Spare wheel 55 plate cooper
Today 01:32 PM
by ajn
Last post by ajn
Today 01:32 PM
0 Replies, 1 Views
R52 A pillar interior trim removal
Today 08:11 AM
Last post by burnstar
Today 11:09 AM
1 Replies, 36 Views
Boot switch not working
Mar 8th, 2014 10:23 AM
Today 11:04 AM
4 Replies, 381 Views
Attention to Detail (UK) - spot the difference!
Today 09:43 AM
by sailesh
Today 10:47 AM
1 Replies, 58 Views
Constant problems with my R50. Should I keep it or replace? Need advice please
Apr 3rd, 2014 03:52 PM
by kteara
Last post by kteara
Today 09:45 AM
13 Replies, 822 Views
Changing Oil????
Mar 3rd, 2014 12:32 PM
Last post by habi222
Today 09:31 AM
8 Replies, 706 Views
Strange Braking Noise
Jan 28th, 2014 08:27 PM
Today 09:21 AM
7 Replies, 935 Views
Electrical Issues with 2003 Cooper base
Mar 10th, 2014 07:09 PM
Today 09:05 AM
2 Replies, 425 Views
Mini Cooper S Rebuild
Today 07:49 AM
Last post by budgie2014
Today 07:49 AM
0 Replies, 46 Views
Cooper S Engine Rebuild
Today 07:44 AM
Today 07:44 AM
0 Replies, 43 Views
Does your Mini have a name?
Mar 25th, 2014 10:00 PM
Last post by johnnycatbiscuit
Today 04:26 AM
17 Replies, 1,020 Views
Engine mounts
Dec 22nd, 2013 07:47 PM
Today 04:21 AM
3 Replies, 781 Views
Buying a cat D insurance loss
Apr 4th, 2014 09:12 PM
Today 04:18 AM
9 Replies, 440 Views
Central Locking Problem Help
Yesterday 04:19 PM
Last post by heathwebbo
Today 12:17 AM
3 Replies, 180 Views
should I wait or not?
Apr 14th, 2014 12:07 AM
Last post by drozd
Today 12:08 AM
6 Replies, 387 Views
Lost locking wheel nut key
Apr 6th, 2014 10:49 AM
by Dazza88
Last post by drozd
Today 12:01 AM
3 Replies, 228 Views
NAVIGATION FIRMWARE dvd
Apr 5th, 2014 03:06 PM
Last post by drozd
Yesterday 11:47 PM
1 Replies, 194 Views
Mini One Silver 2004. FOR SALE
Yesterday 06:58 PM
by 93dlei
Last post by 93dlei
Yesterday 06:58 PM
0 Replies, 107 Views
Will this rear bike rack work on the Clubman?
Jun 6th, 2011 10:18 PM
Last post by sailesh
Yesterday 06:00 PM
3 Replies, 3,949 Views
Which Used Mini
Yesterday 12:31 AM
by UKNY
Last post by UKNY
Yesterday 05:09 PM
6 Replies, 226 Views
Wheel & Tire Center
