rear brake knocking - MINI Cooper Forum
Wheels, Tyres & Brakes
Sponsored by:
post #1 of 3 (permalink) Old Jan 26th, 2014, 11:38 AM Thread Starter
Local Time: 02:47 PM
DIY rear brake knocking
I have a 2002 mini cooper and whilst driving along there is a knocking noise coming from the rear brakes. The faster the travel the faster the knocking. Is there any cure please. All brake pads are relatively new. I have been advised to coat the metal part of the pads in copper grease. This stopped it for a while but the grease gets runny and it starts all over again. HELP!
UKminiman is offline
post #2 of 3 (permalink) Old Feb 14th, 2014, 02:34 PM
Couran's Avatar
Australia
My MINI has just started to knock from the rear brakes, my service is due next Sept, so i think i will be mentioning it to them while i am there. So long as its covered by warranty as it should seeing as it seems to be a common fault.
Couran is offline
post #3 of 3 (permalink) Old Feb 15th, 2014, 12:25 PM
My other car is a Mini
Local Time: 01:17 AM
Quoted: 1 Post(s)
Australia Male
Check the two bolts holding the calipers in place. Mine shook loose, it started with a clunking and rattling noisenoise coming from the rear end, sounded like loose wheel nuts but couldn't locate the source. Worked it out when the caliper fell off.
Richard of the Hills is offline
Rear right brake sticking / dragging kingg47 First Generation MINI Cooper 0 Jul 1st, 2013 10:22 PM
Rear Brake Disc corroded on inboard side jasonofbillinge Wheels, Tyres & Brakes 1 Jun 9th, 2013 05:03 PM
Rear Brake Binding spike47 Wheels, Tyres & Brakes 0 Mar 5th, 2013 09:52 AM
knocking noise from passenger left rear side dessieb123 MINI Cooper Diesel 1 Dec 18th, 2012 07:29 AM
HELP - Rattle/ Knocking Noise from rear passenger side wheel. thegreensnot Second Generation Faults & Fixes 8 Dec 10th, 2012 07:21 AM
