Cooper D R56 rear brake sensor ? - MINI Cooper Forum
Wheels, Tyres & Brakes
Sponsored by:
post #1 of 8 (permalink) Old Mar 7th, 2014, 04:58 PM Thread Starter
Local Time: 01:28 AM
Quoted: 1 Post(s)
Garage
test
greggs is offline
post #2 of 8 (permalink) Old Mar 7th, 2014, 05:20 PM
Quoted: 40 Post(s)
Unless you are very careful/lucky, the wear sensors are single-use only. There is a U-shaped spring clip that fits around the sensor head and holds it in the pad cutout. If that spring clip pinged off into the undergrowth when taking the old pads out, like mine did, then a new wear sensor is the only option.
If your sensor is loose then I suggest that means the spring clip is missing - that was how mine felt before I replaced it. This has nothing to do with contacting the wear sensor - mine was thousands of miles from making contact (I was upgrading the discs to S ones).
Angib is offline
post #3 of 8 (permalink) Old Mar 7th, 2014, 05:51 PM Thread Starter
Quoted: 1 Post(s)
Garage
test
greggs is offline
post #4 of 8 (permalink) Old Mar 7th, 2014, 08:15 PM
Quoted: 40 Post(s)
The spring clip is wrapped around inside the groove in the sensor. Luckily I've just bought one so here it is:
It won't have a part number as it's part of the sensor as far as Mini is concerned.
Angib is offline
post #5 of 8 (permalink) Old Mar 8th, 2014, 01:55 PM Thread Starter
Quoted: 1 Post(s)
Garage
test
greggs is offline
post #6 of 8 (permalink) Old Mar 8th, 2014, 04:42 PM
Quoted: 40 Post(s)
I've not done the rear brakes but I'm fairly sure the sensor clips into the inner brake pad, just like at the front wheel.
Angib is offline
post #7 of 8 (permalink) Old Mar 10th, 2014, 06:28 PM Thread Starter
Quoted: 1 Post(s)
Garage
test
greggs is offline
post #8 of 8 (permalink) Old Mar 10th, 2014, 06:51 PM
Quoted: 40 Post(s)
Just for the record, I checked at the weekend when putting on my summer tyres - the rear sensor does go into the inner (moving) pad, just like the front one.
Angib is offline
R56 Cooper S front and rear bumpers for sale scottish_girly Second Generation MINI Exterior 1 Feb 11th, 2014 04:11 PM
2003 Cooper Rear brake discs fintious maximus Wheels, Tyres & Brakes 2 Oct 13th, 2013 10:57 AM
Rear brake pads discs and sensor 04 cooper mini60 Wheels, Tyres & Brakes 2 Jun 9th, 2013 01:06 PM
