N/S Front Hub/Bearing/ABS Replacement? - MINI Cooper Forum
Wheels, Tyres & Brakes
Sponsored by:
post #1 of 5 (permalink) Old Mar 26th, 2014, 02:44 PM Thread Starter
Local Time: 02:48 AM
Hey,
Does anyone know how to replace the n/s font hub?
My ABS light is on permanently and have been told to replace the ABS ring (which i found is inside the wheel bearing)
I have also been told it is easier to replace the whole wheel Hub unit that replace the individual parts so have bought a second hand one.
I'm not 100% sure on the removal and re fitting are there any links to step by step guides or does anyone have any advice?
Appreciate any help
Ed
edmooreuk is offline
post #2 of 5 (permalink) Old Apr 7th, 2014, 01:35 PM
Local Time: 03:48 AM
I've just done the backs which were a doddle, so I'd imagine the fronts to be equally straightforward.
Wheel off, caliper off, brake disk off and four bolts secure the hub.
Jim
JimH is offline
post #3 of 5 (permalink) Old Apr 7th, 2014, 01:58 PM
Quoted: 53 Post(s)
Ideally if your not sure how to go about it, best leave it to someone who does or can come and give you a hand that knows, its a critical item and needs to be done correctly, and you should use new fixings and torque everything up on assembly.
The Nun is offline
post #4 of 5 (permalink) Old Apr 7th, 2014, 02:30 PM
I've got the torque settings for calipers, hubs, disc retaining screws etc. if anyone needs them.....
JimH is offline
post #5 of 5 (permalink) Old Apr 7th, 2014, 03:04 PM
I'm not familiar the Mini setup but having replaced reluctor rings on other vehicles you'll usually need to remove the driveshaft from the hub assembly, a ball joint or two from the control arms, calipers/discs, etc.
You usually buy the rings separately, chisel/drift the old one off, clean the surfaces, heat up the new one and press on.
Big_Nige is offline
Mini one front seat belt replacement BazzerB First Generation Interior & Ice 1 Mar 15th, 2014 08:05 PM
Replacing Front N/S Wing (A Panel) tom1234177 First Generation MINI Exterior 1 Mar 3rd, 2014 09:16 PM
