Heel and Toe tyre wear - MINI Cooper Forum
Wheels, Tyres & Brakes
Sponsored by:
post #1 of 3 (permalink) Old Apr 7th, 2014, 09:07 AM Thread Starter
Local Time: 05:36 PM
Hi,
Although there are several inconclusive threads about tyre wear and noise, I wondered if anyone has had any definite experience of tyres wearing with a ‘heel and toe’ pattern (i.e. the front edge of the directional tread blocks wearing lower than the rear of the block) and the noise this creates ?
If so, please share ? Did new tyres quieten things down ? What have you done to stop reoccurrence (new shocks, tyre rotation etc.) ?
Cheers, Jim
JimH is offline
post #2 of 3 (permalink) Old Apr 7th, 2014, 02:02 PM
Quoted: 53 Post(s)
Yes on a Jag though as the tyres are nearing the end of their life, and it creates a noise like a wheel bearing is on the way out and a slight shimmer to the steering at higher speeds.
New tyres returns all to normal and I was told its fairly common, oh its the design of the suspension they all go like that eventually.
The Nun is offline
post #3 of 3 (permalink) Old Apr 7th, 2014, 02:34 PM Thread Starter
Cheers.....I never had it on the run flats I had on the car, but non-run-flat Avons have worn like it about half way through the tread on the rears :-(
JimH is offline
Tags: ,
