Right Rear brake sticking HELP!! - MINI Cooper Forum
Wheels, Tyres & Brakes
Sponsored by:
post #1 of 5 (permalink) Old Apr 12th, 2014, 10:42 AM Thread Starter
Mini Cooper S R53
Local Time: 03:34 PM
England Male
I have a 2003 Mini Cooper S (R53) the right rear pads were worn so I changed them. However during this process I discovered that the piston in my calliper was getting stuck out. I have tried winding it in and it just keeps getting stuck out? Do I just need to get a new calliper fitted or is there any way I can fix this?
Also everytime I drive it ATM my actual wheel is getting hot due to the brakes being on all the time! I am now not driving it until I get this resolved.
Any help or advice would be greatly appreciated
Kennell17 is offline
post #2 of 5 (permalink) Old Apr 12th, 2014, 12:19 PM
Local Time: 01:34 AM
Quoted: 127 Post(s)
Australia Male
Garage
Personally I would take it to a brake specialist who may be able to clean up the caliper and piston and rebuild it with new seals, get a quote on an overhaul as opposed to a replacement unit. Compare the cost of both options. Also, did you bleed your brakes after fitting the new pads to ensure no contaminated fluid or air bubbles were in the system.
Milpol is offline
post #3 of 5 (permalink) Old Apr 12th, 2014, 12:27 PM Thread Starter
Mini Cooper S R53
England Male
Thanks for the reply and yes I did bleed brake lines.
I will take it to a garage then.
Any other help on re sealing them yourself (DIY tips) would be great
post #4 of 5 (permalink) Old Apr 12th, 2014, 01:24 PM
Quoted: 3 Post(s)
Australia Male
Garage
New Zealand
You need to buy a repair kit like this one on ebay (This one is for the front wheels though)
I don't know about the quality etc and I'd suggest you do some research on them.
burnstar is offline
post #5 of 5 (permalink) Old Apr 12th, 2014, 07:51 PM
Quoted: 53 Post(s)
You can re seal them yourself with a few tools and a bit of knowledge, and providing the kits is available, but you really ought to take it apart first and strip it because if the piston is badly corroded/pitted then a reseal wont work.
I know it means the car being off the road longer this way so it might not be practical for you to do this.
The Nun is offline
Tags: ,
ICE install, buzzing from rear speakers when brake pedal depressed :( viper8804 Second Generation Interior & Ice 1 Aug 29th, 2013 10:56 AM
Rear right brake sticking / dragging kingg47 First Generation MINI Cooper 0 Jul 1st, 2013 11:22 PM
Rear Brake Disc corroded on inboard side jasonofbillinge Wheels, Tyres & Brakes 1 Jun 9th, 2013 06:03 PM
Sticking rear o/s brake caliper on MCS (handbrake) V6_Ben First Generation MINI Cooper S 5 May 28th, 2013 03:51 PM
Rear Brake Binding spike47 Wheels, Tyres & Brakes 0 Mar 5th, 2013 10:52 AM
