Is heavier tires not fuel efficient? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jan 9th, 2003, 01:42 PM
Local Time: 10:01 PM
United States View elmadi's Liquid Yellow & Black 1st Gen MINI Cooper Profile
I am just wondering if heavier tires like run-flat are not fuel efficient.
Old Jan 9th, 2003, 01:47 PM
LuckyRVA's Avatar
1.6 Litres of fury!!!!
Send a message via AIM to LuckyRVA
Local Time: 12:01 AM
Heavier is always less fuel efficient than lighter. How much less efficient, I couldn't tell you.
2002 Dark Silver Cooper S w/ white roof. SOLD
Old Jan 9th, 2003, 02:43 PM
I guess you are right. Also not to mention rapid aceleration & sudden braking.
Old Jan 9th, 2003, 02:53 PM
cooper4us's Avatar
Local Time: 11:01 PM
United States View cooper4us's Pepper White & Black 1st Gen MINI Cooper Profile
Arrow
That's in the MINI is better to stick to the lightest wheel/tire combo possible and in the case of the regular Cooper, the 15" tires/rims offer the best combination of weight, handling, braking, ride quality and economy.
'02 MINI Cooper CVT
Old Jan 9th, 2003, 03:25 PM
HarryHBMCC's Avatar
Canada Male View HarryHBMCC's Laser Blue & Black 2nd Gen MINI Cooper S Convertible Profile
Arrow
This is not a hard and fast rule. Gas mileage _is_ determined by wheel/tire mass to some extent but more by rolling resistance which is determined by the contact patch and tire characteristics such as tire size and pressure, tread design, rubber compound, etc.
Harry
Old Jan 9th, 2003, 03:33 PM
Apial's Avatar
Local Time: 04:01 AM
United Kingdom Male View Apial's Lightning Blue & Silver 2nd Gen MINI Cooper Diesel Clubman Profile
Wider tyres=more fuel needed. The 15" is available in 175 width. These use less fuel than 195mm or 215mm that come with 16" and 17" wheels.
Old Jan 9th, 2003, 04:31 PM
Wynn's Avatar
Send a message via AIM to Wynn
Making your wheels heavier will not give you a measureable decrease in mileage. It takes more work to start them turning, but once turning, they are not less efficient because of having a greater mass.
Concerns about fuel economy should not deter your selection of wheels based on their weight. But, everyone is right to point out that if the wheels are not merely heavier or greater in diameter, but WIDER, then they'll drag more friction and reduce mileage somewhat.
There's been a tremendously detailed, scientifically accurate thread documenting the influence of different wheels upon accelleration, elsewhere in the forums. A very large difference in the weight of wheels could make enough difference in accelleration for a racer to notice under controlled conditions. But the bottom line for virtually all drivers using a car on the street is that the differences in ride quality and aesthetics are probably much more noticible and important than differences in accelleration, or certainly in fuel economy. That's just not something to worry about.
The most fuel-efficient motorway cruising speed for MINIs hyperbluejames General Discussion 18 Jan 24th, 2007 01:05 PM
Most Fuel Efficient Speed Jonesy General Discussion 23 Jun 1st, 2006 08:55 PM
Why is the MCS so much heavier than the MC? Hubert First Generation MINI Tuning 14 Oct 24th, 2003 03:23 AM
MINI Cooper most fuel efficient gasoline subcompact in Canada HarryHBMCC MINI in the Media 3 Dec 8th, 2002 04:18 PM
