Brake caliper bracket bolts - MINI Cooper Forum
Wheels, Tyres & Brakes
Sponsored by:
post #1 of 5 (permalink) Old May 10th, 2014, 08:25 PM Thread Starter
Local Time: 04:03 AM
I have a 2001 Mini Cooper and I need to replace discs and pads all round. Back are done and were easy. The fronts I'm having difficulty getting the calliper bracket bolts off (not the sliding bolts) and after a lot of swearing and damaged knuckles they need to be taken off with a turbo socket which will ruin it. What I need to know is what bolts do I get to replace them? Please help
Mtbnbmx01 is offline
post #2 of 5 (permalink) Old May 10th, 2014, 09:46 PM
Local Time: 03:03 AM
Hi ya
Have a look at this link
RealOEM.com * BMW R50 Cooper Front brake pad wear sensor
Buy the proper bolts from bmw you only get one chance with brakes don't mess around there not much.
marque is offline
post #3 of 5 (permalink) Old May 10th, 2014, 11:48 PM
Quoted: 25 Post(s)
As marque said get the genuine BMW MINI bolts.
drozd is offline
post #4 of 5 (permalink) Old May 11th, 2014, 02:06 PM
Quoted: 53 Post(s)
As said its absolutely essential you get the genuine parts, dont just go and get some that look similar as the originals will be a high tensile grade spec to cope with the stresses involved.
The Nun is offline
post #5 of 5 (permalink) Old May 11th, 2014, 05:10 PM Thread Starter
Many thanks
Tags: , , ,
JCW Brake Caliper on Cooper S BlueBeastie Second Generation MINI Cooper S 2 Jan 30th, 2014 10:41 AM
Sticking rear o/s brake caliper on MCS (handbrake) V6_Ben First Generation MINI Cooper S 5 May 28th, 2013 03:51 PM
Rear caliper overhaul ewgoforth Wheels, Tyres & Brakes 0 Feb 15th, 2013 01:56 AM
front jcw brake caliper bracket problem morgi27 Wheels, Tyres & Brakes 2 Oct 11th, 2012 09:54 PM
rear brake caliper piston dustcover replacement mini_scotsguy Wheels, Tyres & Brakes 0 Aug 15th, 2012 10:25 PM
