Widening the rear - MINI Cooper Forum
Wheels, Tyres & Brakes
Sponsored by:
post #1 of 4 (permalink) Old Jun 1st, 2014, 06:27 PM Thread Starter
Local Time: 07:43 AM
Widening the rear
Hi,
First of many posts on here I am sure! Not new to the whole owners club thing so know how it works
I have just got my first Mini and once the power steering has been fixed
The mods are likely to begin, One mod I am considering but cant seem to find much advice on is Axel Spacers, I have found people who make them but no reviews ect as to which ones rub ect, I have an R50 Mini Cooper, standard suspension and on 17" S Spokes
Madge Cooper is offline
post #2 of 4 (permalink) Old Jun 1st, 2014, 07:27 PM
Local Time: 06:43 AM
Hi ya
What You are looking for is hub centric wheel spacers. Anything thicker than 5mm on each wheel you will need longer bolts.
The Center bore on the mini wheels are 56.1mm and 4x100 bolt pattern
Depending on what your final goal is there are a few things to consider first.
Are you going to lower how much ?
If so with springs or coil overs ?
what sort of camber and suspension set up do you want to run ie fast road set up or track/road ?
If your going to keep it standard 10 to 15 mm on each wheel should put the wheel in the arch nicely with out rubbing
Don't buy cheep spacers stick to something like eibach, kavs or H&R personally I would speak to rich at orranje, drop him an email and he will sort you out.
And don't forget to get longer bolts
Orranje - New MINI Performance & Styling Products
Hope this helps
marque is offline
post #3 of 4 (permalink) Old Jun 1st, 2014, 08:38 PM Thread Starter
Thanks for the speedy reply! I will lower it at some point im sure but nothing drastic, so springs I think, for now the stock suspension setup is fine, and if push comes to shove i can always take the spacers off, isnt like its a huge job at a huge cost if you get me, will drop rich a line, theres a few things he has i am interested in, thanks for the advice!
post #4 of 4 (permalink) Old Jun 1st, 2014, 08:53 PM
Hi ya
No problem rich will see you right and point you in the right direction.
marque is offline
Water under the rear seats and in the boot Emily88 Maintenance & MINI Care 5 Mar 30th, 2014 04:32 PM
MCS Clubman rear parking distance control juge Second Generation Faults & Fixes 1 Dec 14th, 2013 02:12 PM
Rear right brake sticking / dragging kingg47 First Generation MINI Cooper 0 Jul 1st, 2013 10:22 PM
Rear Brake Disc corroded on inboard side jasonofbillinge Wheels, Tyres & Brakes 1 Jun 9th, 2013 05:03 PM
