front wheel squeaking in hot weather? - MINI Cooper Forum
Wheels, Tyres & Brakes
Sponsored by:
post #1 of 5 (permalink) Old Jun 13th, 2014, 08:40 AM Thread Starter
Local Time: 04:16 AM
hi can anyone explain why this happens in hot weather its mainly when im slowing down to walking pace at a junction, but at speed theres no squeaking???
dessieb123 is offline
post #2 of 5 (permalink) Old Jun 13th, 2014, 11:59 AM
Quoted: 53 Post(s)
Might be brake pads rubbing on the caliper piston when driving slow, if so that can be cured by a smear of some high temp grease, such as copperslip, on the rear of the pads and or anti squeal shims.
The Nun is offline
post #3 of 5 (permalink) Old Jun 13th, 2014, 03:07 PM
Local Time: 03:16 AM
+1
Also it might be worth checking when the callipers are off to that the piston are in good condition and are free and not sticking.
Also if your brake fluid has not been changed for a while it's worth getting that done to.
Hope this helps
marque is offline
post #4 of 5 (permalink) Old Jun 13th, 2014, 03:43 PM
Quoted: 1 Post(s)
Scotland
Hi there, check your brakes, and get a file and take the top edge off of all the pads and also check for any play in your wheels, It could be possible you could have a bad wheel Bearing just starting to let go
Minitech93 is offline
post #5 of 5 (permalink) Old Jun 13th, 2014, 07:55 PM Thread Starter
Cheers for the input will get them checked out.
New mini whurring noise from front right wheel mk1990 Maintenance & MINI Care 4 Jan 15th, 2014 06:20 PM
removing front wheel bearing/hub..... midian-man Wheels, Tyres & Brakes 3 Sep 9th, 2012 05:06 PM
About Front wheel suspension NiuNiu First Generation MINI Suspension 3 Aug 21st, 2012 08:45 PM
