Abs wiring diagram - MINI Cooper Forum
Wheels, Tyres & Brakes
Sponsored by:
post #1 of 3 (permalink) Old Jul 10th, 2014, 01:43 PM Thread Starter
Local Time: 08:47 PM
Quoted: 2 Post(s)
Scotland
Abs wiring diagram
Hi have had abs problem. I've replaced all sensors but it still persists. I also have a bmw c110 diagnostic tool. It's says problem with front left sensor and the pulse to both the front left and right sensor. Have tried erasing codes but they persist. Now want to check wiring from the abs pump. Does anyone have a diagram detailing the pins on the 48 pin plug from the abs pump? Sorry forgot to say its a 2002 cooper
1964geo is offline
post #2 of 3 (permalink) Old Jul 10th, 2014, 11:36 PM
Local Time: 07:47 PM
Hi ya
I don't have a WD to hand at the moment. but the normal places the looms get damaged are just as the loom loops under the abs pump and from the bulk head forwards under the battery tray and around the engine mount.
You have most probably done this but if you have not it might be worth
Make shore the abs pump plug is clean and in good condition and also the ECM (engine control unit) plugs and pins and conectors are ok
Hope this helps
marque is offline
post #3 of 3 (permalink) Old Jul 10th, 2014, 11:45 PM
Hi ya
Right found this any use to you
hope it helps
marque is offline
ABS unit not responding to INPA Russ_T First Generation Faults & Fixes 3 Apr 21st, 2016 11:03 PM
ABS fault JohnnyC First Generation Faults & Fixes 6 Sep 12th, 2015 05:27 PM
AC Condenser wiring diagram gspost12 Second Generation MINI Cooper S 2 Nov 24th, 2013 08:21 PM
Problems installing heated seats retro fit wiring loom - Please help !!! aveze First Generation Interior & Ice 1 Nov 26th, 2012 09:28 PM
R53 ABS issue rare First Generation Faults & Fixes 0 Oct 24th, 2012 05:22 PM
