Jammed lug bolt - MINI Cooper Forum
Wheels, Tyres & Brakes
Sponsored by:
post #1 of 2 (permalink) Old Jul 16th, 2014, 05:06 PM Thread Starter
Local Time: 10:45 AM
United States Male
Jammed lug bolt
Hi:
Mini dealer told my son that during last wheel change to his mini (not performed by the dealer) one lug bolt was jammed.
How difficult is to remove it?
Should he needs to replace the rotor after removing the bolt?
Thnks in advance
Mecaniquito is offline
post #2 of 2 (permalink) Old Jul 17th, 2014, 03:34 PM
Quoted: 24 Post(s)
Are you saying that the MINI dealer has not actually removed the bolt and sorted out the problem before returning the car?
If so, how do they know it's jammed (I assume you mean it has been cross-threaded) or else done up so tight they had trouble removing it?
What have they recommended should be done about it?
Also, are you talking about a standard wheel bolt or is it a locking bolt?
One method of removing bolts is to heat them up with a torch, another is to weld something to the head of the bolt that you can then get a better grip on....this is one way of getting damaged locking bolts out or if you have lost the special bolt locking socket.
Spike
ihughes is offline
4 lug to 5 lug conversion any ideas mini cooper chili s Wheels, Tyres & Brakes 4 May 27th, 2014 10:42 PM
Camber eccentric bolt adjuster problem macrotech General Discussion 0 May 21st, 2014 08:39 AM
Lug Bolt Size? Cobrabud General Discussion 1 May 11th, 2014 01:14 AM
Timing chain tensioner bolt seal ORCHARD51 Second Generation MINI Cooper S 0 Aug 14th, 2013 04:28 PM
