Rattling rear N/S caliper - MINI Cooper Forum
Wheels, Tyres & Brakes
Sponsored by:
post #1 of 4 (permalink) Old Aug 6th, 2014, 03:18 PM Thread Starter
Local Time: 03:50 PM
I have the rattling/knocking rear caliper that I've read is relatively common.
Only when braking gently etc.
Something about a seal failing and causing the caliper to seize a little?
Has anyone fixed this, or am I as well throwing a new (used) caliper on?
NightfireCooper is offline
post #2 of 4 (permalink) Old Aug 7th, 2014, 11:38 AM
Local Time: 04:50 PM
Quoted: 1 Post(s)
Scotland
First thing to do is make sure your spring is still on the calpier. Also make sure that the pads are moving freely and a good quatly pads also I have seen cheap pads causing this fault
Minitech93 is offline
post #3 of 4 (permalink) Old Aug 7th, 2014, 11:43 AM Thread Starter
Thanks for the reply.
Not sure what you mean by make sure the spring is still on the caliper?
This rattling did start immediately after I rotated the wheels, but I didn't notice anything falling off the caliper.
post #4 of 4 (permalink) Old Aug 8th, 2014, 07:16 AM
heathwebbo's Avatar
The rear brake pads have springs on them that are supposed to clip into the piston on the caliper, if the springs are not clipped in the pad can rattle
heathwebbo is offline
MCS Clubman rear parking distance control juge Second Generation Faults & Fixes 1 Dec 14th, 2013 03:12 PM
Sticking rear o/s brake caliper on MCS (handbrake) V6_Ben First Generation MINI Cooper S 5 May 28th, 2013 03:51 PM
Rear caliper overhaul ewgoforth Wheels, Tyres & Brakes 0 Feb 15th, 2013 01:56 AM
rear brake caliper piston dustcover replacement mini_scotsguy Wheels, Tyres & Brakes 0 Aug 15th, 2012 10:25 PM
