Avon ZZ3 Run Flat - MINI Cooper Forum
Wheels, Tyres & Brakes
Sponsored by:
post #1 of 11 (permalink) Old Aug 7th, 2014, 09:04 PM Thread Starter
Local Time: 02:21 PM
Question Avon ZZ3 Run Flat
Hi
Does anyone have these on their Cooper S ?
thinking about putting these on my about to be collected (03) S , Tyres on there at the moment are 3 different types ! want to even things out a bit .
GR03 is offline
post #2 of 11 (permalink) Old Aug 8th, 2014, 09:18 AM
Quoted: 24 Post(s)
I'd switch to non-runflats if you are going to replace all 4 tyres on a 2003 MCS. I'd also recommend Khumo Ecsta's, very good value and excellent wet weather grip. Depends on how many miles you do a year with regard to tyre wear though as Khumo's are not best on wear rates. My tyre supplier doesn't recommend Avon road tyres although does suggest they are great for track and motorsport use.
Lots of good reasons for not using runflats: including, dreadful handling and tramlining, more expensive to purchase initially, often need to be replaced after a puncture if you drive any distance on them etc.
Spike
ihughes is offline
post #3 of 11 (permalink) Old Aug 8th, 2014, 09:27 PM Thread Starter
will I have to make any changes other than just putting non run flats on my existing wheels ?
GR03 is offline
post #4 of 11 (permalink) Old Aug 8th, 2014, 09:38 PM
Caveman's Avatar
Local Time: 04:21 PM
Quoted: 83 Post(s)
You'll have to carry a compressor and tire sealant to deal with punctures.
Caveman is offline
post #5 of 11 (permalink) Old Aug 12th, 2014, 04:46 PM Thread Starter
Thanks Caveman , appreciated
GR03 is offline
post #6 of 11 (permalink) Old Aug 12th, 2014, 07:09 PM
Discovery 4 & Tiger 1200
Tigger, Eeyore & Roo's Avatar
Quoted: 9 Post(s)
United Kingdom View Tigger, Eeyore & Roo's Hyper Blue & White 1st Gen MINI Cooper S Profile View Tigger, Eeyore & Roo's Classified Ads
I ran these tyres for some time on my Cooper S and they were excellent - with a good ride and fantastic wet weather grip. I must have covered a total of over 30,000 miles on them, with probably around another 150,000 miles with ZZ3's on high powered Volvos and around another 20,000 miles in a 300hp Focus RS.
Counter intuitively, the runflat ZZ3's are finer riding than the non runflat versions as they are a lower load rating. In fact, the runflat ZZ3's are finer riding than many non runflats.
Be sure you're looking at the runflats with the correct load rating though, as I didn't think that the correct versions were still made (the ZZ3 has a dramatic tread pattern and new noise regs are not kind to it )
5/04-2/07 R50, 2/07-5/10 R53, all outgrown! Now?:
http://imagizer.imageshack.us/v2/800...922/9FUp72.jpg
Tigger, Eeyore & Roo is offline
post #7 of 11 (permalink) Old Aug 12th, 2014, 07:13 PM
Quoted: 9 Post(s)
Odd that, I've run Avons over many 100,000's of thousands of road miles (after driving around 35,000 - 40,000 miles a year, for the last 33 years, I reckon to have done half of that total on Avons) and can't understand why he has a problem. Maybe there's a greater chance of maintaining a living margin on Korean tyres?
post #8 of 11 (permalink) Old Aug 12th, 2014, 08:36 PM
Quoted: 12 Post(s)
Avon ZZ3 is a good tyre, I haven't used it as a runflat, but have done about 20 laps of the Nurburgring on them and used them daily too, plus weekends to and from south coast, no noise issues, or any other, and wear very well. I believe they're standard fit on some Rolls or Bentley cars?
Pretty sure in non rft's they're being superceeded by ZZ5?
ExclusiveWorkshops is offline
post #9 of 11 (permalink) Old Aug 12th, 2014, 10:25 PM Thread Starter
Thanks Guys , always nice to get lots of feedback .
will check on the RF versions , sure they are still available from some suppliers
GR03 is offline
post #10 of 11 (permalink) Old Aug 13th, 2014, 05:49 AM
Quoted: 9 Post(s)
No noise issues with them here either, but changing regulations on new tyres demand ever quieter tyres and these were designed more for wet weather grip than ultimate low noise output.
post #11 of 11 (permalink) Old Aug 13th, 2014, 05:54 AM
Quoted: 9 Post(s)
I remember it being easy to confuse the two as even the non runflat version misleadingly has "RF" on the sidewall (RF, as in "reinforced", in this case though). The only way of telling for sure that it was the right one was that it had the standard load rating, rather than the higher "reinforced" load rating.
Run Flat Tyres & Dash Indicator and standard wheels? stargirl169 Wheels, Tyres & Brakes 10 May 30th, 2015 06:24 PM
Run Flat & DSC lights always on? lukejade First Generation Faults & Fixes 4 Mar 26th, 2014 03:01 PM
Run Flat Warning display Paulstar808 General Discussion 1 Feb 2nd, 2014 05:38 PM
Run Flat Question samowens Wheels, Tyres & Brakes 1 Jul 13th, 2013 09:09 AM
Non run flat advice... ben_uk Wheels, Tyres & Brakes 0 Jan 1st, 2013 07:29 PM
