Well, You can try unplugging your battery for a few minutes and that "should" clear up the codes... But if your still having problems after that u can take it to your local shady mechanic with a car scanner and clear the code with the computer, Unless you have a diagnostic car computer laying around the battery trick is your best bet :biggrin::biggrin::biggrin::biggrin:
The service reset on Gen1 doesn't clear the brake light.
try this:
"The MINI uses a Brake Wear Sensor on the front left and rear right brake pads. When the brake pad wears down, the brake pad wear sensor is also worn down and will eventually trigger the warning light to alert you. Once the warning light is triggered, the wear sensor needs to be replaced.
After replacing the sensor, turn the ignition key to the #2 position for around 30 seconds without turning over the engine...the light goes out! "
Related Threads
MINI Cooper Forum
3.6M posts
159.9K members
Since 2001
