Visit Derek Woodman MINI
Old Apr 6th, 2003, 02:26 PM   #1
pkrehbiel
MINI2 Sponsor
pkrehbiel's Avatar
Local Time: 01:59 PM
Thumbs up 225/45-17 F1 GS-D3 & 17" R90's
I just had Goodyear F1 GS-D3 225/45-17 tires mounted on my MCS with the factory 17" R90 Wheels and 0.6" dropped H&R springs. They drive, handle, ride, and grip fantastic! Needed a little dremel work on the inside of the rear wheel well liners. Still slight rubbing only in the rear on really big bumps, but nothing serious. Setup is much more neutral now than with the runflats.
Love 'em!
Pete
United States Male View pkrehbiel's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 8th, 2003, 10:29 AM   #2 (permalink)
RSAmerica
Local Time: 02:59 PM
The 225/45/17 is a little on the tall side 24.9" dia vs 205/45/17 (stock) at 24.1" dia. I went with 215/40/17 at 23.8" dia which is smaller than stock.
United States View RSAmerica's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 9th, 2003, 08:45 AM   #3 (permalink)
Southernsun
Send a message via AIM to Southernsun
car looks really tight! i have one question. my mcs is dropped 1.0 f, and 1.2 for the back. i want to add 215/45 17 on my stock 17" s-lites. can it be done? will the tire rub at the wheel axel? i know there's room between fender and wheel, my concern is the inner part.
United States View Southernsun's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 10th, 2003, 01:23 PM   #4 (permalink)
helmi_45
helmi_45's Avatar
got picture of those 215/40/17? do they look wider than stock or about the same?
Old Apr 11th, 2003, 06:38 AM   #5 (permalink)
pkrehbiel
MINI2 Sponsor
pkrehbiel's Avatar
United-States Goodyear F1's from Behind
They definitely widen the stance from stock. I'll post a better picture as soon as my MCS comes back from getting the BMP Aux Gauges and Cold Air Intake installed.
Old Apr 11th, 2003, 08:43 PM   #6 (permalink)
Boris
Southernsun,
I have 215/45-R17 Michelin Pilot Sport on 38 offset BBS RG-R wheels with a stock suspension. They do not rub, but if I were to lower the car they would!!!! The rear has minimal clearance to a point that if I were to push the car, the tire diflection might rub the inside of the outer fender wall. I haven't gotten to the limit, yet only 820 miles on the car.
You will need an offset of of at least 42 to avoid rubbing altogether.
BTW, why put on 215/45?? I did it for pothole protection in NJ and I'll be getting the JCW kit, so power won't be an issue.
Regards,
Boris
JC Works - MCS Chili Red w/White spinning a 19% -
Euro Gruppe Tuning
United States View Boris's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 12th, 2003, 11:36 PM   #7 (permalink)
Southernsun
boris,
why the 215/45? same reason, the potholes. and also that the ride is lower, i though a little more rubber will protect the wheel. meaning, 215 is just a little higher than the 205 profile. yes, my car is lower, but i don't think it will rub at the inside of the outer fender well. my concern is the wheel axel, or anything in that area that being a wider tyre.
Old Apr 13th, 2003, 06:33 AM   #8 (permalink)
toofast
Re: 225/45-17 F1 GS-D3 & 17" R90's
Love 'em!
Pete
What exactly did you drim with the dremel... Did you just cut the inner wheel well liner? how did you seal the liner and sheet metal so that water will not spray onto the backside of the rocker pannel?
I have 215/45 17 snows on now with no rubbing whatsoever but I fear that when I install my H&R springs some triming may be necessary. So any ideas would help!
Old Apr 14th, 2003, 08:09 PM   #9 (permalink)
Boris
Southernsun,
Potholes, uneven pavement, etc. My previous car had a race tuned suspension. Sort of a skateboard like ride. The new mini is not a race car, just occational autocrosser, so comfort becomes a factor in any performance upgrade I do.
Besides, sticky wider tires will outperform a spring change in the mini. The only reason to lower w/o tire change is for looks. I went the other route by enlarging the wheel diameter.
-Boris
Euro Gruppe Tuning
Old Apr 14th, 2003, 10:36 PM   #10 (permalink)
pkrehbiel
MINI2 Sponsor
pkrehbiel's Avatar
A liitle foam rubber and duct tape sealed the cut in the wheel well liner.
Old Apr 15th, 2003, 10:20 AM   #11 (permalink)
Southernsun
Boris
i understand what u mean. yeah, the pirelli's and eibachs work well. but i would like a nice heafty well made tyre. i was told not to change the run flats cuz of the fact they are run flats! but i want a normal tyre with good performance as well. i had a 2000 civic Si, with a real slammed suspension *3 1/2" drop!* but i'm very pleased with the eibachs now, agressive look witha very comfy ride.
Old Apr 15th, 2003, 08:17 PM   #12 (permalink)
Boris
Southernsun,
I finally uploaded a couple of pics into my gallery. Crappy shots and you really don't get the view of how tight the space between the tires and body panels really is, but its still a couple of pics.
-Boris
Link to Gallery
Euro Gruppe Tuning
Old Apr 16th, 2003, 02:40 AM   #13 (permalink)
toofast
slightly wider flares and wells
Boris you suggest a 42 offset I would have to agree that that should solve the problem I have a 40 ofset kosei K1(215/45/17) and have not experienced any rubbing yet...it is very close...it must be DANGER close with 38 offset
Do you know of a reasonably light wheel with a 42 offset most I have seen are 45,40,38 etc...
Really what would solve everyones problem is if the wheel wells did not flare down... I have done a little research and none of the aftermarket kits are to my liking with the exception of Bryton (Cooper only).
I will be intalling my summer tires/wheels when I put on the new H&R springs so Ill be fine I just need to solve this issue between now and next winter.
I plan to use my mini on a few high speed road courses in the area THERE IS NO SUBSTITUE FOR A GOOD SUSPENSION IMHO
Old Apr 16th, 2003, 10:03 AM   #14 (permalink)
Southernsun
Boris,
thanks for the pics. i see what u mean. the tire is closer, i must agree. and your car really looks nice. i will decide soon what to do. as know the stock S lites are a 50 offset so i think i will be fine with the 215, we'll see. i did some spirited driving today and the tyres kinda concerned me. although the eibachs were working well, the pirelli's got me thinking. i know there are WAY better tyres out there. by the way, your car looks great! hope to put pics on soon also.
Old Apr 16th, 2003, 08:40 PM   #15 (permalink)
Boris
Southernsun,
I PM'ed you.
As far as offset, the BBS RK's, OZ Chrono, Centerline RPM are offered in 42 offset. The OZ Superleggera in 18x7 is available in 42 offset.
I checked my rear tires yesterday and they are even with the outer wall of my fender. Now I know that the suspension will camber the tires in on bump, but probably not enough to clear. The 42 should be fine.
Regards,
Boris
Euro Gruppe Tuning
Old Apr 17th, 2003, 09:05 AM   #16 (permalink)
Southernsun
Boris,
i haven't recieved your pm. i don't even recieve email notifications for when i reply to a topic anymore! yes, the offsets seem to be from 38-43 for aftermarket wheels. i kinda like the way the stock S lites look with the 50 offset. especially with the car lowered. i think any where from a 44-50 offset is perfect for the mcs. although some offsets of 38-43 look great as well, like yours. thanks for sharing your info and advice in this post. if i make any new modifications *tyres, etc* i'll let u know. i think i will put the bonnet scoop mesh grill next. www.minicooperparts.com -seems to look pretty neat. if u have any questions as well, feel free to ask.
Old May 1st, 2004, 02:29 AM   #17 (permalink)
minigolf
Blue is the colour!
minigolf's Avatar
Local Time: 05:59 AM
I have the same size tyre on my GTI, and am thinking of getting them again for some aftermarket 17s when my MCS arrives. Now that you have had these tyres a while, can you post your thoughts on your experiences with them on your MINI.
Cheers Liam
Quote: Originally Posted by pkrehbiel
They definitely widen the stance from stock...
http://www.mini2.com/forum/attachmen...chmentid=13773
Australia Male View minigolf's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 1st, 2004, 10:02 PM   #18 (permalink)
Ibb
MINI2 Master BLASTER!!!!!
Ibb's Avatar
Local Time: 07:59 PM
Send a message via ICQ to Ibb Send a message via MSN to Ibb
MiniGolf what aftermarket wheels are you thinking of?
United Kingdom Male View Ibb's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 13th, 2004, 09:36 AM   #19 (permalink)
EBMCS03
M5 Extraordinare!
EBMCS03's Avatar
Local Time: 11:59 AM
Send a message via ICQ to EBMCS03 Send a message via AIM to EBMCS03 Send a message via MSN to EBMCS03 Send a message via Yahoo to EBMCS03
Do you know if they will rub on a stock set up, no lowering of the car. I want to put 225s on mine also.
EB/W MCS Arrived (3/26/03) Premium & Sports Package, Lapis Blue Leather, Harmon Kardon, PDC, Tint, Aux Input, X-Pel Clearbra *SOLD* 4/25/06
United States Male View EBMCS03's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 15th, 2004, 03:01 PM   #20 (permalink)
Mini4000
Mini4000's Avatar
hi,
i drive a mini COOPER and wouldn.t a 215/45r17 be too LARGE for my car, and wont it rub too hard, and will the car handle sameways as before or will it handle worse ....
I love the goodyear eagle gs d3, but they havent got them in the standard 205/45/r17 size ??
And the 215/45 ' s are cheaper then the standard size 205/45 here in Belgium. it seems that this (205/45r17) is an not so common tire size....
thx
Belgium   Reply With Quote
My new pepper white w/ aero kit & r90's SimonSJR 2nd Gen MINI Cooper 21 Jan 10th, 2007 07:44 PM
How much extra will a dealer charge for 17" R90's ? andy_leitch MINI Cooper 4 Feb 26th, 2005 08:09 AM
Best 17" tyre for R90's on a Cooper? aphix Wheels, Tyres & Brakes 12 Jul 6th, 2004 06:52 PM
16" One Piece R90's - Price? anthonyyule Wheels, Tyres & Brakes 3 Aug 30th, 2003 08:42 PM
18" with 225? Grinder Wheels, Tyres & Brakes 1 May 22nd, 2003 11:16 PM
