Inside of both rear tires wearing Once again, I am turning to all of you! You have helped me out in the past, so I thought I would let you ponder this. Got my MCS the last week of June 02. The last week of October I had to replace my passenger side rear tire (17" dunlop running flats) because unfortunately, I hit a curb. While cleaning the brake dust from the wheels this past Sunday, I noticed BOTH rear tires are wearing on the inside. Now, the newly replaced tire is only 5 months old & the other is 9 months old. Just hit 12000 miles. Both tires have identical wear. This surely doesn't seem normal. A lot of the posts I have read here relate to the front tires, but not the rear. I am getting ready for my first oil change/service w/in the next 2 weeks & I wanted to see what kind of leg I have to stand on in getting my tires replaced at no charge. Any & all responses are greatly appreciated and thank you in advance! |
| 10,000 miles on my 17" pirellis, and yes..there's a "tad" more wear on the inside of the rears. All else seems even. Ken Shapiro Electric Blue w/ Sport Package...first "S" delivered in Maryland (5/10/02) I've been everywhere but the electric chair...I've seen everything but the wind. |
Rear tire wear Curious what you were told by dealer on rear tire wear. Mine pretty much said it was normal to wear the inside. I too have same problem with much more treat remaining everywhere but the inside of of both rear tires. On my car the drivers side rear inside shows the most wear. Did not rotate tires but will on next set. |
| I had this problem with my 02 JCW with JCW suspension & JCW wheels and was told that I should probally get a yearly alignment to help prevent irregular wear. Since I have an 02, The rear could not be set at factory specs ( rear bars not adjustable) so I replaced rear lower bars with Hsport adjustable. Greta's rear spec is now correct. Hopefully this will get me a bit more tire mileage. ![]() ![]() NOTE: Bar was adjusted to factory setting thus difference in length. Later |
| Removing Inside rear window sticker.... | superdupercooperS | First Generation Interior & Ice | 9 | Sep 5th, 2006 09:47 PM |
| Water on inside of rear screen? | Bilbo Baggins | First Generation Faults & Fixes | 3 | Apr 14th, 2004 07:38 PM |
| UnionJack sticker wanted - inside on rear window | Dennis77 | General Discussion | 10 | Nov 18th, 2003 09:46 PM |
| Wheels/Tires in Rear Seat Area | Andy@Ross-Tech.com | MINI in Motorsport | 7 | Jun 16th, 2003 10:35 PM |
