Tyre pressures, effect on ride and handling - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Apr 19th, 2003, 12:31 AM
mark-wiz's Avatar
Local Time: 09:16 AM
United Kingdom View mark-wiz's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
My Cooper has the Chili pack 5-star 16" alloys with runflat 195/55 R16 tyres.
The owners manual recommends setting the pressures at 30psi f/r. When set at these pressures (checked with a BMW digital gauge) the car hops about a bit on poorly maintained roads (aren't they all?).
I have recently lowered them to 25psi f/r and this has transormed the ride dramatically, although the steering feels a little heavier.
Will this have an adverse effect on general handling? Is it dangerous/illegal? Has anyone else experimented with different tyre pressures? Opinions please.
Old Apr 19th, 2003, 08:13 AM
Local Time: 04:16 AM
United States View Bino's Chili Red & White 1st Gen MINI Cooper S Profile
Running off-spec tire pressure causes uneven wear. Lower pressure typically causes more wear close to the tire's shoulders. Higher pressure usually causes more wear in the middle of the tread. While it is possible to "tune" a certain amount of over- or under-steer with minor tire pressure variations, if what you're after is a softer ride, you might be better off buying different tires.
Old Apr 20th, 2003, 09:36 PM
HarryHBMCC's Avatar
Local Time: 03:16 AM
Canada Male View HarryHBMCC's Laser Blue & Black 2nd Gen MINI Cooper S Convertible Profile
Running lower pressures can give a softer ride and better traction under some conditions (drag racers run with a big sloppy contact patch from low pressure). But running too low will be dangerous at high speed, both for maneuvers and because the tire will heat up. 25PSI is on the low side though on average, people around the world commonly run 5PSI low without knowing it.
It is best to run with at least the recommended tire pressure used. If you find that too rough a ride then 15" wheels and non-runflat tires might be more comfortable for you.
Not sure about the legality in your area. Here failure to maintain your vehicle could be cause of fault in an accident, and that includes the tires.
Harry
Old Apr 23rd, 2003, 01:21 AM
Local Time: 02:16 AM
United States View elmadi's Liquid Yellow & Black 1st Gen MINI Cooper Profile
Harry
Well said!
Old Apr 23rd, 2003, 05:42 AM
I've just recently played around with the pressures in mine. Using my ropey old foot pump, 2.0 bar gave a bouncy ride, 2.2 bar gave a harsh ride and light steering, but 2.1 bar is perfect (all cold readings taken first thing in the morning). Oh, isn't that the recommended pressure. If you would like to borrow my pump, let me know, only a few hundred miles away.
Also, I'm no expert, but as has already been said; I would imagine that should you be unfortunate enough to have an accident and your tyres are significantly under the recommended pressure, then your insurers may hold this against you in settling any claim.
ian
Old Apr 23rd, 2003, 07:12 AM
Boo's Avatar
Boo
Sponsor and Widget
Local Time: 06:16 PM
Australia View Boo's British Racing Green & White 1st Gen MINI Cooper S Profile
I recommend that if you want a soft comfortable ride, drive a Volvo otherwise, drive your Mini like you stole it at recommended pressures
The original SWORKS
Old Apr 23rd, 2003, 07:41 PM
You are number 6
Send a message via Skype™ to Mike Clarke
Local Time: 04:16 PM
Australia Male View Mike Clarke's Solid Black & Body Color 1st Gen MINI Cooper S Profile
A few years ago I did a driving course and the instructor insisted on all tyres being at 34 to 35 psi, irrespective of manufacturers recommendations.
The reasoning was that manufacturers recommend on the low side to ensure plushness of ride. Higher pressures give more accurate steering, better tyre wear, better braking and better fuel consumption, and a harsher ride.
I recently increased the pressure in my crapelli P3000s to around 32 to 33 psi and not only does all of the above seem to hold true but they have also stopped their incessant squealing.
I second Boo's comments. Soft and comfortable have no place in the world of the MINI driver.
Old Apr 24th, 2003, 08:00 AM
Hehehe...
Anyone else remember that Hunter S. Thompson pumped up the tires of his ragtop Caddy ("The Shark") to 50 psi in order to improve the handling?
Why does ride height effect rubbing/fouling? SteveM3 First Generation MINI Suspension 3 Jun 19th, 2006 12:33 AM
what tyre pressures to use L18AOK Wheels, Tyres & Brakes 10 Apr 24th, 2006 07:45 PM
MSC Runflat pressures v ride comfort JohnWB Wheels, Tyres & Brakes 0 Sep 7th, 2005 12:35 PM
Handling/ride differences with new wheels Kerley Wheels, Tyres & Brakes 0 Jun 23rd, 2004 06:14 PM
Tyre pressures (2) J.N. General Discussion 2 Apr 9th, 2002 03:15 PM
