I bought a set of cooper s alloys (8 spokes it wont let me post a photo as I have less than 15 posts) second hand. they seemed in good enough condition, the guy said they were off his wifes cooper s but she wanted other wheels hence selling these.
first problem encountered was I couldnt get 2 of the caps off bc they were "locked" had to use an injector pin to unlock them - is this normal?
they have reasonable pressure but I wanted to pump them up more prior to putting on my car. but they arent taking in any air, when I attached the air hose to the valve literally nothing happens. it usually bleeps at me tells me to put the hose on properly then I readjust and it starts putting in air and displays the pressure increasing or if already at desired pressure the display will flash.
but I just got nothing. the display continually sat at the desired pressure, it didnt read the pressure of the tyres or pump any air in.
It wasnt the pump faulty as i tried it on my current wheels and worked as normal.
does anyone have any ideas? i dont own a mini i'm putting them on a car with the same fitment so not sure how mini alloys/tyres usually work but i'm sure they would just pump up like normal tyres.
appreciated if someone could shed some light on what might be the problem
