| wrt 215/45r17 wouldn't that be a bit too big for the wheelwell? stock is 205/45, I figured that the drop to /40 would compensate for the 215/... then again the diffrenece is .9cm so mebbee its not a big deal :-) what is the largest tire dimension one can place on an MCS w/o rubbing or throwing off the speedo and odometer? -RS (hopefully) 2004 MINI Cooper S 2003 Audi A4 3.0 Quattro 2002 VW Passat GLX 4motion (RIP) |
| If you look in the faq, specifically http://www.mini2.com/forum/thread3493_.html you'll see that 215/45R17 is at the top end of the acceptable size, at least for speedometer/odometer readings. I suspect it will fit fine on stock suspension setups. Harry MINI Cooper Cabrio: now the car with go cart handling really feels like an open go cart! "... the only man that can come home at 3 am in the morning without getting into trouble with his spouse is the owner of a British sports car!" -- Phil Bailey |
| Hmmm ContiExtremeContact pretty much seems the way to go (still trying to figure out what to do about flat tires...) has any heard of ContiPremierContacts? Conti's website refers to them as having gone on sale may 1st, but google brings up no other matches than the manufacturers website... (hopefully) 2004 MINI Cooper S 2003 Audi A4 3.0 Quattro 2002 VW Passat GLX 4motion (RIP) |
| Guys, I am having the same trouble myself. My Mini S is not here yet but it will be here in a month. I am considering the same exact tires. However, til now, I am still looking for advise if I should go with 215/40/17 or stock size 205/45/17. With the STOCK susp. setup, am I going to have any trouble with 215/40s? I know this guy in Hong Kong has 215/45/17 but he said the tires will rub even with 1 passenger in the car! But he has KW coilovers. According to Grassroot Mag. (www.grmotorsports.com) their project Mini S has 215/40s but they change the susp. at the same time. So doesn't help on that one. PLEASE can someone tell me if it is ok to go with 215/40/17 with stock susp? Oh BTW, I have 40mm off set for the rims too.... (Volk Racing GT-P) |
| I also currently running tire size of 215/40/17 with stock suspension and even now with 1.5" lowering springs. Therefore i can safely say NO they wont rub even with 4 185+ people in the car. been there , drove that. Now just noticing the offset you put down for the Volk rims might make it a slightly different story in your case. The off set says how far your tire sticks out. and this may cause a rub if it sticks out to far. I think but dont quote me on this the stock rims are 42mm off set. Which means they stick 2mm farther into the car than the Volk. Also meaning you may get a rub from your outside fender and not the suspension. 02 MCS DS/W (Totaled November 02 on Fall Folage Run) 03 MCS DS/W (See my MINI Profie for extensive list of mods) |
| so 215/40/17s are safe... 215/45/17s will have a better ride, but they are risky if one modifies their suspension... how about w/ a stock MCS setup? (I have no intention of doing anything w/ the suspension for a long long time, cosmetic mods, JCW kit and some better brakes will keep me busy for the forseable future) (hopefully) 2004 MINI Cooper S 2003 Audi A4 3.0 Quattro 2002 VW Passat GLX 4motion (RIP) |
| I ran 215/45/17 Kumho's with the stock suspension with no problems. When I added coilovers and lowered the car a bit -- still no problem - Until I loaded up the car for a trip - Me, Wife, luggage, extra set of wheels & Tires, tools, etc. (autox journey) I then had rubbing in the back over bumps etc. |
| 215/45 or 215/40 (17") | adn | Wheels, Tyres & Brakes | 24 | Sep 27th, 2005 01:04 AM |
| make up my mind, please - 215/40 vs. 215/45 | bodinski | Wheels, Tyres & Brakes | 4 | Nov 12th, 2004 08:22 PM |
| 215/40 or 215/45 17" with lower springs picture? | My Pocket Rocket | Wheels, Tyres & Brakes | 0 | Sep 24th, 2004 02:36 PM |
| 235/40R17 is it possible? | minimc | Wheels, Tyres & Brakes | 10 | Jun 14th, 2004 04:23 AM |
| Which profile? 215/40-17 or 215/45-17 | OZChris | Wheels, Tyres & Brakes | 24 | May 30th, 2004 12:40 PM |
