Hi, like it says in the title really, does anyone have photos or diagrams of the wire routing for the front LH and rear RH brake sensor?
My story is that I got a local garage to change discs and pads, front and rear
Then 2 months later the brake warning light came on again
Took it back to the garage who took it away for a look and came back 20 mins later to say can't find a problem and will need to book in for 2-3 hours for a thorough check
I questioned why as I had no problems before I took the car to them for new discs/pads!!
Anyway, curious that I am, I took the front LH wheel off this afternoon and within 5 minutes I found the problem.
The garage hadn't bothered to use any of the wire clips on the sensor wire and it had worn down to the metal against the drive shaft!!
Needless to say I'll be going back to the garage next week to have it out with them but I'll be fitting the new sensor wire!!
