6f7 - MINI 60mm CUSTOM Center Caps - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jun 8th, 2003, 08:26 AM
RobbyTT's Avatar
Local Time: 06:24 AM
Hello my good sir.
I have the same wheels as you (Team Dynamics Pro Race 1) and I saw your How-to to make the stock MINI center caps fit. I really want to do this You did some serious great work.
However, after searchin on the Lowes site online, and visting 3 Home Depots (we don't have Lowes in Chicago) I can't find that friggin' part. The Carlon E950JH. I can't even find something close to it!!
Would you be willing to pick up 4 of them for me at the Lowes where you got yours and ship them to me. I'll can pay for them anyway you want. Paypal ..
Sorry, I don't have your email
Thanks!!
1978 Porsche 911 SC Targa
2000 Audi TT Quattro Coupe
2002 MINI Cooper
Old Dec 13th, 2003, 02:44 AM
MINI finally
Local Time: 07:24 AM
I'm in the same boat, Pro Race 1's are in the mail and I need to start thinking about the center caps. Peter at Rspeed said that one of their customers found 60mm caps at a local tire shop, maybe an NTB, he was going to try and find the details. Are your Pro Race 1's relatively new, and you've confirmed that they are 60mm? I read something subtle about a change in the center cap design recently.
In the meantime, Lowe's looks like my best bet, we do have them in NC. I have not yet looked but probably will this weekend. Searching the web, I found several electrical supply sites which carried Carlon. Here's one which actually shows this part:
http://www.munroelectric.com/catalog/carlon/bodies.html
It almost looked like they wanted to sell by the carton, though. Wanna make a carton of these? I'll buy 4. ;-) I'm not sure I've got the tools to do a nice job on this.
I'll let you know if I find them at our Lowes or I may be placing an order.
Later,
Scott
Old Dec 13th, 2003, 03:23 PM
Local Time: 05:24 AM
Fitment issues?
I've also got a set of the Pro Race 1's, that I dropped off at the dealership this week for mounting (they're 'buying back' my S-lites from me). The tech from the dealership called and said the wheel is 'loose' on the hub. She wasn't sure if it needed a hub ring or a wheel spacer, but felt it wasn't safe as is. Has anyone else experienced this problem? I got the 17x7", 4x100 PCD, 45ET. I really don't want to use wheel spacers if I can avoid it, so that I can use H-sport lowering springs and not have any rubbing issues.
I'll also be trying to construct some center caps as well, once I can get them on the car.
Old Dec 13th, 2003, 07:34 PM
MINI finally
They need hub centering rings, whoever sold you the wheels should have them. The mechanic is right, you shouldn't mount them without, they won't be centered properly on the hub.
Scott
Old Dec 17th, 2003, 04:43 PM
6f7
Just saw this thread--The part I described was a coupling for electrical conduit. I thought the part number would save time. I would assume that most hardware stores will carry electrical coupling.
Also keep in mind that there are two versions on the TD pro race 1's. The race version (that I have) will not accept a centercap and you will have to make one. The second version will accept a TD centercap that sticks out from the center by 1/2". If you have the second, you could just get the MINI centercap decals from your parts department and stick them on the TD centercap. How can you tell which you have? The second version has a little raised "lip" around the centercap hole while the first race version has a mitred edge around the hole.
I want MINI center caps for my aftermarket wheels... tinfro Wheels, Tyres & Brakes 7 Jul 5th, 2007 02:10 AM
Can OEM MINI center caps fit on 16" R84 X-Lites? nulltty Wheels, Tyres & Brakes 3 Nov 3rd, 2004 04:06 PM
Center caps hopper Wheels, Tyres & Brakes 0 Jul 6th, 2004 09:46 PM
My new custom center caps paulmon Wheels, Tyres & Brakes 15 Sep 2nd, 2003 03:08 AM
ISO: 60mm Center Caps 6f7 Wheels, Tyres & Brakes 1 May 1st, 2003 12:21 PM
