all bling and no zing? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Aug 7th, 2003, 02:44 AM
Local Time: 05:12 PM
I'm still looking around for aftermarket wheels, but am having second thoughts about it. The reason is that I found out (thanks FAQ section) that the R81 (7 hole wheels) that comes stock on my cooper weigh only 12lbs each!!! So my question is there any benefit in buying 17" aftermarket wheels? Is it purely for aesthetic reasons with no performance advatages? Does the increase in size make up for the increase in weight because even the lighter 17s like the OZ superleggera are still over 4lbs heavier than the r81s. Anyone have some input on this?
thanks,
seth
Old Aug 7th, 2003, 02:58 AM
nfo
Local Time: 11:12 AM
you're right!
lightweight 16's are the best compromise.
good looks, light weight!
Old Aug 7th, 2003, 08:38 AM
Paul's Avatar
MINI2 No.1
England Male
Originally posted by nfo
you're right!
Agreed.
Old Aug 7th, 2003, 09:23 AM
bigbaddaboom's Avatar
Send a message via MSN to bigbaddaboom
French Polynesia View bigbaddaboom's Solid Black & Body Color 1st Gen MINI Cooper S Profile
The new Velox pg-Rev10 17s are only 11.5 lbs, they don't look too bad either.
Old Aug 8th, 2003, 02:03 AM
i totally agree with Paul BUT
i still bought 17inch wheels, i think they look great and my FORGED 17inch wheels weight around 15lbs, yeah not as light as the 16s, but i also want strength too. the fact their forged helps, but if they're too light they can only be but so strong...
Old Aug 16th, 2003, 11:39 AM
Mugami's Avatar
Local Time: 01:12 PM
United States View Mugami's Dark Silver & White 1st Gen MINI Cooper S Profile
other thing is the 15" wheel are only 5" wide. while most of the 16" and 17" are 7" wide. The type of tyre that can fit on the bigger rims are softer and sticker than those that can fit on the 15" stocker. Which gives you better take off and handeling. Not saying you cant get a wide 15" which solves even that problem. Currently i run the Centerline Impulse rim 17" which weighs in at 11.5 lbs. But with tire it wieghs in at 31.5 lbs. The Stock 7 hole with tire wieghs only 24lbs. Which is lighter cause your only running half the tyer. than on the 17's. I do run the 15" for the winter being thinner it helps in the snow.
02 MCS DS/W (Totaled November 02 on Fall Folage Run)
03 MCS DS/W (See my MINI Profie for extensive list of mods)
Bling bling :-) Chrome scoop and driving lamps Assimilate First Generation MINI Exterior 7 Jan 3rd, 2007 12:23 AM
Mr Toad's wild ride. .from Bling to Zing Mr Toad General Discussion 10 Jun 20th, 2006 06:16 PM
BLING BLING is here pixs at last taz2822 First Generation MINI Convertible 37 Apr 21st, 2005 04:49 AM
Bling Bling! New chrome parts added Cooperchris First Generation MINI Exterior 38 Nov 3rd, 2004 06:55 PM
