| "Only initialize the system if the inflation pressure, e.g. after a tire change, has been corrected." So, make sure each tyre is at the correct pressure for the amount of passengers/luggage etc., and:- "1. Ignition key in position 2. 2. Press the button long enough for the yellow indicator lamp in the instrument cluster to light up for a few seconds [the button under the handbrake]. 3. Start the engine. After a few minutes driving time, the Flat Tire Monitor sets the current inflation pressure in the tires as the target values to be monitored." Why can't they spell TYRE correctly? |
| You're aces, MarkW19! "Why can't they spell TYRE correctly?" ![]() My mis-spelling forced me to double my search efforts herein! -Thanks again, MarkW19! Going to try it all now, - had to take a brake for breakfast w/ the wife. |
| I'm pretty sure that sound is just the parking brake 'releasing'. When you jack up the car and then drop it back down, the parking brake will bind a little. When you release it, it sort of pops. Now did the EML light come on or the tire pressure light? I can see the tire pressure light coming on (mine usually does when i switch tires) but not sure why the EML one would... |
| Still lookin' into it. Thanks 4 responses.... 1) The 7-holey's are groovy, man! ![]() 2) We can get ugly winters in the upper-midwest (though the last few years have been very cold without the snow). The R90 run-flat combos weighed-in at some 22kg & have excellent tread remaining, a bit wider than preferable for snow, but their weight-tread combo will be great for getting down to the road surface on snowy days. The R81s weighed-in at less than 14kg with non-runflat shoes. ![]() I guess it should go backwards, - large wheels for summer, smaller for winter; (as ALEX@TireRack stated), but the MINI wheel weighting is all wrong that way. R90s are too g.damn heavy for any perk, performance-wise. I just don't see any way around that,- except that they too, look fab! 16" wheels should be the superb summer-lovin' choice, - but there are no substantial weight savings to be had in the MINI 16"ers. Aftermarket wheels for the MINI are abundant & brilliant, yet much more expensive than nabbing a set of MINI take-offs. ==> I paid $202USD for a full MINI set, shipped 1200 miles to me. In aftermarket wheels, that'd get me about 1 new wheel. I'm always looking to find efficient upgrades. I'm saving for a proper ECU upgrade, as our baby's had software-related hiccups, stumble, power-loss & Yo-yo. I don't mind the hiccup/Yo-Yo always happening when cold/at start-up, but, the ones that leave you half-in an intersection with no power, no warning or predictability are enough to scare you stupid [which has obviously already happened to me.] -Thanks for answering mates, much appreciated! I'd rather turn into MINI2.com than my dealer's lot! You all kick-tush! Last edited by SugarBelly; Aug 31st, 2003 at 07:33 PM. |
| Howdy, minhi! Great clue, minhi: "I'm pretty sure that sound is just the parking brake 'releasing'. When you jack up the car and then drop it back down, the parking brake will bind a little. When you release it, it sort of pops. I'd guess now, that's exactly what it was! ![]() Next: "Now did the EML light come on or the tire pressure light? I can see the tire pressure light coming on (mine usually does when i switch tires) but not sure why the EML one would..." It's the Flat Tire Monitor according to the (US-spelled ) Owners Manual. The manual goes on to help a great deal, "Stays lit: the system is defective. Please have the system inspected at your MINI dealer." Thanks! It "gongs" a warning sound, then continues flashing this symbol: {_!_} I'm headed out to check pressures & then re-"Initiallize the System" as suggested by MarkW19. One note, I'm going with 30/210psi/kilopascal. [Usually 2 at most in the car.] Please advise here as needed! There are no direct suggestions for 205/60/15s which I've got. 2nd note, The gentleman mounting/balancing my new shoes said one tire/rim combo wanted a little extra weight attached, then still wobbled, - ever so slightly. He thought it wasn't enough to replace, but I mounted it on the back as an extra measure of caution. If worst comes to worst, that'll likely be the culprit. Thanks again, all. -.s.b |
| i'm pretty happy with my after market intake (rogue), it got rid of the yo-yo for me and the car takes off from a stop better in heat. i'm also very happy with my aftermarket wheels, yeah they were expensive, but they dropped around 15lbs per corner (from the s-spokes/s-lites). The make the car much more enjoyable to drive. |
| 19" Wheels & Tires | ShyGuy | Wheels, Tyres & Brakes | 4 | Jun 16th, 2005 08:26 AM |
| 18 " wheels & tyres | DJZ1873 | Wheels, Tyres & Brakes | 2 | Feb 1st, 2005 09:14 PM |
| 18" Wheels & Tyres Now On | Bonnie Scotland | Wheels, Tyres & Brakes | 71 | Feb 12th, 2003 12:22 AM |
