Runflat tires - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Sep 29th, 2003, 01:09 AM
detroitwing14's Avatar
Local Time: 03:12 AM
Runflat tires
Has anyone ever had a problem with their runflats? Have they ever gone flat and been undrivable? Also, has anyone noticed problems with wear, etc?
Btw, i was asking because i dont know if i should buy a spare for long trips to put in the boot.
Old Sep 29th, 2003, 02:19 AM
jsteine2's Avatar
How well, not how much.
Local Time: 11:12 PM
Switzerland View jsteine2's British Racing Green & White 1st Gen MINI Cooper Profile View jsteine2's Classified Ads
Nothing here... the wife had 10,000 on hers before we downsized for winter. No noticable wear, no problem. Undoubtably, as with many car problems, it depends on how you drive.
Hers: '02 LY/white, CVT ...... His: '04 BRG/white
In order to possess what you do not possess
You must go by the way of dispossession.
In order to arrive at what you are not
You must go through the way in which you are not. (T.S. Eliot, East Coker III)
Old Sep 29th, 2003, 02:21 AM
Sponsor/Moderator/Other
Local Time: 10:12 PM
United States View stryder's Hyper Blue & White 1st Gen MINI Cooper S Profile
Look through the tyres forum, there's lots of information there. Some people have had runflats get sidewall punctures, and like all tires, they're not repairable, but of course without air, they can be driven up to 50 miles, or as your manual says depending on the amount of air hundreds of miles on low air.
Whether you want to get a spare is questionable, if you're looking at a donut mini-spare, its probably not worth it, since they can only got 50 miles no matter what, which your runflat will be able to do even with an 1" hole in the side, but if you want a normal sized tire, it could be worth it, but it'd take up a lot of boot space.
Rememember the tires can be replaced with 'normal' tires, so if you're in the middle of nowhere, you can have a tire shop replace your tire with something in a similar size and just continue on and get it fixed when you're back somewhere that has the correct tire.
The tires wear quickly, but that's mostly their design, not being runflats, check the tyres forum again for threads on that so you know how much to expect your particular brand to last.
Magic 8-ball was correct. All be in awe of Magic 8 ball.
Old Sep 29th, 2003, 02:26 AM
United States View moorlockx's Solid Black & White 1st Gen MINI Cooper S Profile
For long trips I'd get a spare. The runflat may be able to get you to a safe spot, but at night or in the more desolate areas, you might have problems finding someone to repair/replace it. With the spare you can change it, keep on motoring, then get it fixed the next day when the stores are open.
-- '03 S B/W Magnaflow; Cibie lights; Madness intake; white 17" Team Dynamics; H&R springs; Helix swaybar; custom stripes
The ultimate runflat tires rsinsheimer Wheels, Tyres & Brakes 3 Jan 17th, 2009 03:28 PM
Garages in SF that can runflat tires jonkudla Northern California Region 3 Oct 23rd, 2004 02:04 PM
Runflat tires dmac5 Wheels, Tyres & Brakes 4 Oct 19th, 2003 09:06 PM
Runflat tires ??? MoMini General Discussion 0 Mar 20th, 2002 04:04 PM
Runflat Winter Tires? noahe First Generation MINI Tuning 4 Dec 27th, 2001 03:13 PM
