Yokohama Parada Spec-2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Nov 18th, 2003, 12:41 AM
MINIMENC's Avatar
Local Time: 03:13 PM
United Kingdom View MINIMENC's British Racing Green & White 1st Gen MINI Cooper S Profile
United-Kingdom Yokohama Parada Spec-2
All,
Got my tirerack.com sourced Parada's mounted this weekend. What a difference!! Much smoother ride, the tires absorb much more of the rougher road surfaces I encounter on my daily drive. They replaced the stock Pirelli Euphoria p.o.s.'s that came with the car. I'm no expert on tires but I can say that this is how the S should have ridden before. It will be a while until I release the hounds on these tires but so far I am impressed.
One worrying doubt I had was that the pattern on the Parada's looks like the tires should be directional and asymetrical. Nothing on Tirerack or the tires themselves indicated that they are directional but if you look at the pattern, your brain is telling you otherwise. I had a long discussion with my installer and wasn't particulary satisfied with their response. So, I called Yokohama today (great customer service) and they confirmed that they are NOT directional and that they get a lot of calls about this. Just to confirm, if you look at the back of the car, the pattern in the tyres, or the "swoop" starts from the top left to bottom right, on both sides of the car. They do need to be mounted correctly with the large circumference groove on the outside of the wheel.
Finally, FYI - it took the installer over an hour just to remove the original Euphorias and about the same time to mount the Parada's - they complained about the very stiff sidewalls on both sets.
So that's my 2 cents worth. Thought I would pass the info along.
G
Old Nov 18th, 2003, 02:04 AM
MINIAC's Avatar
Canned
Local Time: 12:13 PM
Minimenc ...
Thanks for including the tire information in your MINI Profile and voting in the approriate tire poll
Old Nov 18th, 2003, 03:30 AM
Local Time: 08:13 PM
United States View red03miniS's Chili Red & Black 1st Gen MINI Cooper S Profile
dont know why it took your wheel shop an hour to install the yoko
my tire shop did the install in like 25 min..i got yoko es 100s.
the parada are good tires, but i know of 2 other mini owners who will never get them..because how loud they get when they start wearing down...
good luck nonetheless
2003 CR MCS and 2007 CR MCS (on order)
Old Nov 19th, 2003, 08:13 PM
Romhog's Avatar
My mini is my casket
Send a message via ICQ to Romhog Send a message via AIM to Romhog Send a message via Yahoo to Romhog
United States View Romhog's Dark Silver & Black 1st Gen MINI Cooper S Profile
Its a price you pay for more rubber to the pavement. Its just like the Magnaflow debate about performance over noise. You dont get something for nothing. More rubber to the road = more noise but also = better grip.
I still plan to get these tyres.
Old Nov 19th, 2003, 10:40 PM
make sure you rotate the paradas often, they easily develop heel/toe wear. very often this is the cause of the excessive noise people complain about.
personally i think they're over-rated, i'm halfway through a set now and i think the grip is just average even compared to the dunlops.
ride is much better then the dunlops though.
Yoko ES 100 vs. Parada Spec-2? kapps Wheels, Tyres & Brakes 1 Jun 9th, 2005 07:15 PM
Yokohama AVS100 vs. Parada Spec-2 ? lotoole3 Wheels, Tyres & Brakes 7 Oct 6th, 2004 04:23 AM
Any UK S's got Yoko Parada Spec 2's mark Wheels, Tyres & Brakes 0 May 6th, 2004 01:19 PM
