Replacing factory run flats ? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Nov 20th, 2003, 03:19 PM
greatmeadows's Avatar
Local Time: 10:13 PM
Unhappy Replacing factory run flats ?
Hi,
I've read the important facts re: replacing run flats with conventional tires. I have an MCS with 16" wheels and find the ride around town in traffic and where the pavement isn't perfect to be harsh and bumpy. My wife and I are in our 60's and while we both love everything else about our MCS, this one complaint is frustrating our ability to truly enjoy the car. Ironically, the factory setup makes this a superb highway car. If I spring for conventional tires, will this remove enough of the harshness from the ride to justify the expense? Or is the suspension most of the problem here? Anyone out there with this experience? Again, I'm not interested in replacing the run flats for a better performing tire , just a more comfortable one, and they need to be all season.Thanks for any insight you can share on this issue.
Gene Cosloy
Old Nov 20th, 2003, 07:32 PM
milliethemini's Avatar
Rep withdrawal sucks.....
Local Time: 07:13 PM
View milliethemini's Indi Blue & Body Color 1st Gen MINI Cooper S Profile
I can see how the sport suspension plus on the MCS may contribute to the 'livelier' handling of the car on imperfect roads. The MC has a sport suspension too, but not as firm as the SS+. If the MCS is the MINI you want, you will have to live with the SS+.
Having said that, I believe the that firmer sidewalls of the runflats do play a factor in the ride of the car on bumpy roads, as in contributing to a harsher ride (the lack of flex is not a big factor in highway driving, especially if most of it is interstate driving.) Conventional tyres should give you a more compliant ride, but I will leave that for MCS owners who have swapped their tyres to give you the definitive word on that (I still drive on my runflats).
In the meantime, have you tried playing with the tyre pressure of your tyres? If you are still using the OEM 195/55/16's, try the minimum of 33 PSI, or even 32 PSI. Anything to reduce the firmness of the tyre within safety limits, that might help a little.
Old Nov 20th, 2003, 09:41 PM
DeniseK's Avatar
Local Time: 09:13 PM
United States View DeniseK's Liquid Yellow & White 1st Gen MINI Cooper S Profile
Well, as someone who lives on a washboard-rutted road, I have driven with both runflats (my car) and Toyos (someone else's car) and the Toyo tires gave the much smoother ride.
DeniseK
Old Nov 20th, 2003, 09:55 PM
obehave's Avatar
Mini Mod
Local Time: 11:13 PM
I just changed mine out. Actually mounted tires on another set of rims, stock X-Lites.
I was pleasantly surprised at the difference. It doesn't make the car all comfy riding but it does remove just enough of the harshness to make the ride more pleasant. I really didn't have a problem with the runflats but the change is nice.
Car handles mmuch better as well.
Old Nov 20th, 2003, 10:05 PM
jsteine2's Avatar
How well, not how much.
Switzerland View jsteine2's British Racing Green & White 1st Gen MINI Cooper Profile View jsteine2's Classified Ads
The wifes CVT came with 17" runflats... she wanted to drive it this winter so we found a set of 15" take off OE wheels and tires... made a world of difference! Not just in ride, but in gas mileage as well.
Hers: '02 LY/white, CVT ...... His: '04 BRG/white
In order to possess what you do not possess
You must go by the way of dispossession.
In order to arrive at what you are not
You must go through the way in which you are not. (T.S. Eliot, East Coker III)
Old Nov 21st, 2003, 07:35 AM
Local Time: 08:13 PM
I have heard that going from 16" runflats to 17" non-runflats actually improves the ride comfort. I know Pirelli makes some of the most comfortable Max Performance Summer tires on the market, but you'd need to do a little poking around to see what the best one is in the Ultra Performance or All Season categories.
Old Nov 21st, 2003, 02:33 PM
obehave's Avatar
Mini Mod
Actually just moving to non runflats is the difference. Since the 16 will have a taller sidewall height it should be more compliant than the 17s.
That and he already has 16" rims.
Just nitpicking
Old Nov 22nd, 2003, 01:13 AM
The point was that going from 16" to 17" will decrease the ride comfort, whereas going from runflats to non-runflats will increase the ride comfort. In the example I stated, rim diameter increase had less of an effect than switching to non-runflats.
The idea was to emphasize that going from 16" runflats to 16" non-runflats should dramatically increase ride comfort and take out the harshness greatmeadows is experiencing.
Old Nov 22nd, 2003, 05:48 AM
Local Time: 03:13 AM
United States View red03miniS's Chili Red & Black 1st Gen MINI Cooper S Profile
i saw go with some michelin tires on the 16 inch wheels
you will see a world of difference
2003 CR MCS and 2007 CR MCS (on order)
Old Nov 22nd, 2003, 10:09 AM
work, work, work...
United States View agiduda's Dark Silver & Black 1st Gen MINI Cooper S Profile
Last night I took my 94 RX-7 with Bridestone 245/45/16 S02s out for the first time since getting my MCS w/17" runflats. I was suprised how much harsher the 7 is than the MCS. Maybe I have one of the newer "softer" MCSs, it was built 9/03.
(I was also suprised how explosive the 7s power was, that thing is a beast.)
I still prefer to drive the MCS, it's just more fun and much better on fuel consumption!
Replacing run-flats ps_minics Wheels, Tyres & Brakes 2 Nov 7th, 2006 10:54 AM
Replacing Run Flats on MCS chrisjt Wheels, Tyres & Brakes 1 Sep 15th, 2005 08:55 PM
Replacing Run Flats... djbohne Wheels, Tyres & Brakes 1 Apr 4th, 2005 06:19 PM
front run flats need replacing jeff90 Wheels, Tyres & Brakes 4 Sep 27th, 2004 10:26 AM
Replacing front run-flats only ? johnl Wheels, Tyres & Brakes 16 Sep 4th, 2003 05:30 PM
