Tire Pressure? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Dec 12th, 2003, 01:01 AM
flatsix02's Avatar
Hulk.
Send a message via AIM to flatsix02
Local Time: 10:13 PM
United States View flatsix02's British Racing Green & Body Color 1st Gen MINI Cooper S Profile
Tire Pressure?
So tonight i thought my tires looked a little low, so i took my BMW tester and went around and tested multiple times, very cold tires too. Havn't driven for a few hours and its only 20F.
Heres my results: LF - 31 RF - 29 This was with multiple tries and resets too, is this normall??
LR - 29 RR - 29
Thanks,
Scott
Old Dec 12th, 2003, 07:18 AM
milliethemini's Avatar
Rep withdrawal sucks.....
Local Time: 07:13 PM
View milliethemini's Indi Blue & Body Color 1st Gen MINI Cooper S Profile
It depends on what size tires and wheels you have on your MCS. But regardless, 29 - 31 PSI is low, and should be considered underinflated.
Don't be surprised with the low tire pressure; during the winter time car tires do lose pressure more rapidly due to the temperature.
Check your owner's manual to see what the recommended pressure is. I know that on my MCS, with standard 195/55/16 runflats, the minimum is 33PSI. With a full load, 38 PSI. I put my tire pressure in between, at around 36 PSI, because I like a firmer ride, and also because in the wintertime, I can go a 2-3 weeks without checking the tire pressure and know that even if I lose 2-3PSI during that period, the tire pressure is still within the safe limit.
If you have aftermarket tires, check the tire sidewall to see what the max PSI rating is. It's recommended to check your tire pressure monthly, but in the wintertime I would recommend doing it weekly.
Old Dec 12th, 2003, 07:33 AM
KenL's Avatar
Local Time: 04:13 AM
I thought the reduced pressure was just due to the temperature difference not that the tyres lose air more in the winter.
Pressure and temperature are proportional so lower temperature gives a lower pressure reading.
I usually check my pressures every two weeks or so.
Old Dec 12th, 2003, 09:54 AM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
I know 30PSI all round is the correct pressure for Runflats on the Cooper with the 16" 5 spokes. Why is the S so much more?
It was acceptable in the 80's
Old Dec 16th, 2003, 08:08 PM
Local Time: 08:13 PM
I almost always drive by myself, or with one passenger, so I use the lower recommended number for my MC, which is 30 front, 30 rear. I check my tires every two weeks, and if they drop to 29.0, I'll pump them up to 31.0.
Old Dec 16th, 2003, 08:20 PM
DJC's Avatar
DJC
United Kingdom Male View DJC's Chili Red & White 1st Gen MINI Cooper Profile
If you are running the 17" wheels, try 32PSI all round, it works for me. Damian.
Old Dec 16th, 2003, 08:21 PM
NEMINI.org
United States View NEMINI's Silk Green & Black 1st Gen MINI Cooper Profile
open your door and look on the body for the tag with pressure recommendations you should always follow manufacturers recommendations, not what is printed on the tire itself.
Old Dec 16th, 2003, 08:33 PM
jasonfields007's Avatar
Send a message via MSN to jasonfields007
Local Time: 03:13 AM
United Kingdom Male View jasonfields007's Classified Ads
whats the best pressure to have with 16" on the cooper s
'06' Cooper S Convertible - Astro Black, '04' Mazda RX8 231 - Black
Old Dec 16th, 2003, 08:40 PM
HarryHBMCC's Avatar
Canada Male View HarryHBMCC's Laser Blue & Black 2nd Gen MINI Cooper S Convertible Profile
As people have said above, this information is available on the tire placard. Generally 30PSI for light loads, 35 for full loads or 33 if you just want better handling with a light load. 30PSI is 2 bars, 35PSI is about 2.5 bars, IICC.
Harry
Old Dec 16th, 2003, 09:26 PM
SteveM3's Avatar
Tire pressure needed varies due to production tolerances in tyres, weight of
the car and driving style. It is also influenced by temperatures and the fact that
guages are rarely pin point accurate. However in the long term there is a real
simple way to tell. Get a tread depth guage and check your tyres every few
thousand miles. If the tyre is losing tread fastest on the outside your tyre is
underinflated and you should try a higher pressure. If the tyre is losing tread
fastest on the inside your tyre is overinflated and you should try a lower
pressure. If tyre wear is uneven side to side then get your suspension
checked. When you have even tyre wear it means the whole tyre is being
used which will gives you the best mileage and the most grip .
Old Dec 16th, 2003, 10:04 PM
Minimum's Avatar
MINI2 Something or Other
I was driving in a parking garage recently. While making a hard right turn, I heard rubbing. When I got home, I couldn't see anything and eventually checked the pressure. They varied between 23 and 25 pounds all around. I have the 195/55/16 run-flats. I think I'll check the pressure a little more often.
tire pressure????? gregc Wheels, Tyres & Brakes 1 Sep 3rd, 2005 03:52 AM
tire pressure carguy54 Wheels, Tyres & Brakes 1 Apr 20th, 2004 11:39 AM
Tire pressure ice Wheels, Tyres & Brakes 8 Jun 19th, 2003 10:49 PM
Tire pressure? K-Rog First Generation MINI Tuning 3 Aug 2nd, 2002 10:09 AM
