Fitting R85 S-spokes Question - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jan 12th, 2004, 02:45 PM
Local Time: 03:13 AM
United Kingdom Male View S33BBY's Hyper Blue & Black 1st Gen MINI Cooper Profile View S33BBY's Classified Ads
My MINI One is due soon, and it is coming with the standard steel wheels. I am getting R85 S-spokes from MINI @ £130/wheel and fitting my own tyres (Michelin Pilot Sport 205/45 R17) hence the reason for not buying 4 wheels with tyres @ £1,065.
MINI want £175 to fit the wheels, so I'm going to go to another garage to have them fitted. I've read many posts about garages over-torquing, so my question is: is there anything specifically I should tell them to do when I take them to be fitted?
Many thanks.
2006 MINI Cooper with JCW Sound Kit - sold July 2009
Now driving Golf VI GT TSI 1.4 160PS
Old Jan 12th, 2004, 03:14 PM
obehave's Avatar
Mini Mod
Local Time: 11:13 PM
Just ask them nicely BEFORE they start the work. Express how important it is toyou to have it done correctly.
It'll be hard to find a place that'll actually use a torque wrench though.
Old Jan 12th, 2004, 03:21 PM
Thanks for your reply.
I understand that the tyre pressures are listed in the manual, so I'll look this up.
Reading around the forum, the correct torque setting seems to be a bit of a hazy subject area. From what I've read, the official setting is 88.5lb/ft. Is this correct?
Old Jan 12th, 2004, 08:16 PM
brassd's Avatar
United Kingdom View brassd's Hyper Blue & White 1st Gen MINI Cooper S Profile
Black Cooper
I did mine myself using the supplied tools from MINI. It really wasn't a problem.
Dave
Old Jan 12th, 2004, 08:17 PM
DJC's Avatar
DJC
Local Time: 04:13 AM
United Kingdom Male View DJC's Chili Red & White 1st Gen MINI Cooper Profile
Hi, hope this does not sound rude but, treat yourself to your own torque wrench, and if they cannot do it, at least when they have finished, you can do it and be sure it is right. I think the torque setting is 100nM, but do not quote me, maybe check with your dealer. The dealer price sounds very high to me. Also remember after about 100-150 miles check the wheel nuts again, just in case. Hope this helps, Damian.
Old Jan 12th, 2004, 09:12 PM
Thanks for the reply; I may just do this.
I think you are right that the torque setting is 100nM, that's the equivalent of 88.5lb/ft.
Old Jan 12th, 2004, 11:45 PM
obehave's Avatar
Mini Mod
It's 120Nm. I think that converts to 88-89lb/ft.
Some parts stores here will let you borrow tools. If you can't afford the torque wrench right now (or just don't want to buy one) see if you can borrow one for a bit.
Old Jan 13th, 2004, 07:49 AM
randap's Avatar
Hangin at the Krusty Krab
United Kingdom Male View randap's Solid Black & Body Color 1st Gen MINI Cooper Profile View randap's Classified Ads
Get a torque wrench and DIY. That'll be a lot cheaper than getting them fitted, and you can take as much are as you like, and be confident that they are correctly fitted. You'll also have your own wrench and a heavier wallet.
Try Halfrauds, about £50 for a good one with snap settings (you dial the torque you want, then pull until the wrench "snaps", and hey presto you're done - set once, and all nuts will have the same torque).
fitting s-spokes in the boot? IML337 Wheels, Tyres & Brakes 4 Dec 1st, 2003 10:28 PM
do you have to put runflat tyres on r85 s-spokes? Pepper'D Wheels, Tyres & Brakes 1 Jun 26th, 2003 12:25 AM
