Is it OK to run non-runflats front and runflats back? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jan 30th, 2004, 09:51 PM
Local Time: 03:14 AM
United Kingdom View Darren S's Dark Silver & Black 1st Gen MINI Cooper S Profile
Question Is it OK to run non-runflats front and runflats back?
My Pirelli Runflats are practically bald at the front so I think it's time for some new tyres. I definitely want to get normal tyres instead of the runflats but is it ok to keep the rear runflats on for as long as they last, with normal tyres at the front?
Old Jan 30th, 2004, 11:36 PM
obehave's Avatar
Mini Mod
Local Time: 11:14 PM
I really wouldn't recommend it. But then again you wouldn't be the ony person doing it, others have.
Old Jan 30th, 2004, 11:53 PM
Local Time: 08:14 PM
Mixing RF's and non-RF's isn't much differenent from mixed different brands of (non-RF) tires... People do it, but it's not recommended.
Your ride will feel strange, as one set of tire will be stiffer than the other.
Your handling will be somewhat unpredictable, as the break-away characteristic of the front end will be different from the rear; they'll heat up at different rates; etc.
Can you rotate the tires and get some more life out of the them?
Old Jan 31st, 2004, 12:26 PM
Silver Black
No chance, the nearside front is pretty much a slick, and the offside is getting close(if not already) illegal.
I might just bite the bullet and change all four.
Old Jan 31st, 2004, 04:34 PM
DJC's Avatar
DJC
Local Time: 04:14 AM
United Kingdom Male View DJC's Chili Red & White 1st Gen MINI Cooper Profile
Hi Darren, i have fitted 2 new Pirelli PZero Assim on the front, and still got r/flats on the rear. In my opinion it feels fine, but maybe if you push them you might get different traction from eash set, but at least they are the same manufacturer. Will also replace rears in the next 3 months, but the ride and feel are much nicer than the runflats. Hope this helps, Damian.
Old Jan 31st, 2004, 04:47 PM
Silver Black
Thanks Damian, I think I'll keep the rear run-flats on to start with and make up my mind after driving it for a bit. If you don't mind me asking - how much did the Pzero's cost you, and where from?
Darren
Old Jan 31st, 2004, 05:12 PM
Silver Black
Quote: Originally Posted by Max
Darren
BMW don't recommend running on a mixture as you suggest.
If you have an accident that involves a skid or a failure to stop, your tyre combo will be blamed, you will also have invalidated your Warranty and possibly your Insurance.
Unless you notify your insurance company that you have modified your car in this way (against the manufacturer's recommendation) you may invalidate your insurance.
That's the formal. official position.
I would personally not have a mixture of RF and non-RF on my car; I would always have that niggling doubt about the safety/insurance issue.
regards
max
Hello Max,
So are you saying it may invalidate my insurance and warranty by having a mix, or just not having run-flats?
Old Jan 31st, 2004, 05:27 PM
Thumbs up
Cheers for the info Max.
Old Jan 31st, 2004, 05:38 PM
obehave's Avatar
Mini Mod
You have to bear in mind also that that if you get too many miles on then rotating the tires becomes a bit odd.
Old Jan 31st, 2004, 06:31 PM
obehave's Avatar
Mini Mod
Yo, obe, how ya doin?
Surely not a problem? Say you have normal fronts with 10,000 miles on. You ditch the RF off the back, put the 10,000 mile worn normals on the back and 2 (same brand) normals on the front.
Job done, no?
regards
max
Not bad and you.
Yea that would work if you plan on never rotating them again. But the whole point to rotating frequently is to keep tire wear even. Thus keeping tire adhesion and handling balanced.
Uneven tire wear might be OK on some underpowered beater that handles like a bag of water but I wouldn't want a MINI (even my Minivan) compromised like that.
Old Feb 2nd, 2004, 10:32 PM
DJC's Avatar
DJC
Hello Darren, my PZero`s cost £100 each, all in. They were fitted at a friends tyre place.
Old Feb 7th, 2004, 12:50 AM
Positively a "no-no". Although it may feel fine at normal speeds, first time you decide (or an incident on the highway decides) to corner hard, you are in a very dangerous situation. The sidewall stiffness on a run-flat makes it a much different responding tire than a non-run-flat. Just changing tread types is a dangerous move on a car that handles as well as the MINI. When pushed to the limit you want all the tires to react the same way at the same time. Replace them in sets.
Old Feb 7th, 2004, 10:28 AM
DJC's Avatar
DJC
Hello again. I think that someone posted on here that one of the Cooper S tuning companies uses non runflat on the front, and runflat on the rear. Also if you are trying that hard on the road, maybe you should be on a Trackday, not the road. Just my opinion. All the best Damian.
Old Feb 10th, 2008, 06:22 PM
there is not a problem with bmw mini with a mix of tyres front and rear; but best to stick to the same brand.
  #15 (permalink)
Old Feb 17th, 2009, 08:51 AM
UJOC no. GB067
Local Time: 06:14 AM
Finland Male View tcbw's Dark Silver & Black 1st Gen MINI Cooper S Profile
I wouldn't do it; just need to go the whole hog and get the full set
Run flats on rear non runflats on front? Jaw_F430 Wheels, Tyres & Brakes 2 Sep 10th, 2007 09:42 PM
Runflats Vs non Runflats ride quality WORKSRACER Wheels, Tyres & Brakes 11 Jan 18th, 2006 05:18 PM
Can I replace front 2 runflats with nonrunflats? AmRov Wheels, Tyres & Brakes 10 Jul 23rd, 2005 06:07 PM
I replaced my 17" runflats on S-spokes with 16" non-runflats on X-Lites beej Wheels, Tyres & Brakes 2 May 25th, 2005 05:05 PM
How many miles should your 17" Front runflats last BRGreenie Wheels, Tyres & Brakes 23 Oct 10th, 2004 07:27 PM
