| Replacing Runflats with NonRunflats I read the FAQ and searched, but it wasn't exactly clear: I need to replace two of my 17" Pirelli tires. I'm on a relatively strict budget right now and may in fact be selling my beloved MINI by summer's end. 1. If I buy non-run flats, does the run-flat sensor need to be disabled? 2. If I get a flat, what then? I have Triple A, but without a spare what do they do? Trailer it? Fix it on the spot? Thanks! Oh, and these are the tires I'm considering: http://www.tirerack.com/tires/tires....um=045WR7ES712 again, I'm looking for a good bang-to-buck ratio as I'm a bit poor right now Dark Silver "S" - White Top - Alloy Wheels - Sports Package - Premium Package - status: In Search of Twisties |
| Well, since you did make an effort to do a search and find the information first , let me help you out with your questions:1] Unlike the Chevrolet Corvette, which has runflat tires but utilizes an expensive sensor inside each rim, the runflat sensor on the MINI is much more rudimentary. The sensor is not inside the rim, but is instead located somewhere on the ABS assembly. The sensor detects a difference in tire pressure through any differences in the rotational speed of all 4 tires. In effect, it only detects differences in tire pressure, whereas the one on the Corvette also keeps track of the exact tire pressure of each wheel. Refine your search, type in 'runflat sensor', this will bring up more detailed threads on this topic. Here's one as an example: http://www.mini2.com/forum/showthrea...runflat+sensor 2] I assume that you drive a MCS? If so, you have no spare tire to fall back on - and you are taking a calculated gamble using non runflats instead of runflats. Keep a tire air compressor and can of Tire Gunk in your car at all times. I believe that AAA will only help you change your flat tire, not fix it, so without a spare tire that's a moot point. To tow a MINI, it has to be trailered, so I also think you will be out of luck with AAA, as I don't think they use tow trailers. I don't have 17's on my MCS, so I will let someone else help you with your tire choices But I think you should have 4 of the same tire on your car, not 2 different types. Different brands and models of car tires have different characteristics, and putting two different pairs of tires on your car could negatively affect the handling (and safety) of driving it! |
| The tire-pressure monitoring system warns you when any tire’s pressure drops below 70% of normal, so you want it active regardless of what type of tire you're running. You should carry a mobility kit if you're running conventional tires without a spare: http://www.mini2.com/forum/showthrea...kit#post782046 Are you just planning on replacing the two worn tires? ![]() |
| If you ever do need a tow from the AAA, make sure you request a flatbed tow truck from the operator. In my experience, they will honor this request. It may take a longer wait time for the AAA to source a flat bed and have it come to you, but your MINI will avoid damage. I would also recommend buying a second tow hook to supplement the one supplied with your MINI. That way, the tow truck driver can better secure your car on the flat bed without resorting to finding the wrong thing under the car to use as a tie down point. + 2002 MINI Cooper S - Dark Silver / White roof, Sport, Premium, Lapis blue leather + 1965 Mini Traveller - Tartan Red / White roof, 1275, Cooper S discs, fully restored/renewed |
| They were the Falken ZE-512....3000 miles on them sofar all looks well. The spare and jack set me back 2 big ones.......highway robbery...welll i feel safer now when I am on the road. I will never have runflats again....they dont wear worth a s... Gary from Memphis – Chili Red S White top SP/PP delivered 7/30/2002 |
| Replacing Runflats | K1 LYC | Wheels, Tyres & Brakes | 13 | Sep 13th, 2006 04:35 PM |
| 16inch runflats versus 17inch nonrunflats | cct1 | Wheels, Tyres & Brakes | 4 | Sep 2nd, 2005 09:36 AM |
| Can I replace front 2 runflats with nonrunflats? | AmRov | Wheels, Tyres & Brakes | 10 | Jul 23rd, 2005 06:07 PM |
| My experience with replacing runflats | kapps | Wheels, Tyres & Brakes | 7 | Jun 27th, 2004 10:57 PM |
| Only Replacing Fronts w/ Non-Runflats? | GTmini | Wheels, Tyres & Brakes | 15 | Oct 14th, 2003 03:45 PM |
