fronts on rears / rears on fronts ? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Dec 30th, 2004, 05:44 PM
Local Time: 04:28 AM
my front toyo's are obviously wearing alot quicker , is it worth swapping them round to get a bit more mileage out of the set or will it cause problems ?
steve
Old Dec 30th, 2004, 06:11 PM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
There have been many posts about this. Try doing a search.
In a nutshell all you're going to do is have to replace 4 tyres at once by doing this. There are also potential handling problems with running a set of front worn tyres on the back and the backs on the front.
The search should tell you more
It was acceptable in the 80's
Old Dec 30th, 2004, 06:33 PM
dansmini's Avatar
Sullivan Racing
Local Time: 11:28 PM
United States View dansmini's Chili Red & White 1st Gen MINI Cooper Profile
If you wait until there is uneven wear, you probably shouldn't rotate the wheels. Ideally, you should rotate the wheels every 5000 miles (maybe less) so that you get even wear. At least, that is what I do and it seems to be working.
Old Dec 30th, 2004, 07:05 PM
minicooperphil's Avatar
i agree with these two guys, however i changed mine when the fronts were only 1mm legal. ive had no problems, if anything the car has become even more fun as on damp roads you can get the back out really easily. woohoo! had the worn tyres on the back for 4months done about 5000 miles of hard driving and they havnt changed, still 1mm legal.
Mix 215/35/18 Fronts w/205/40/18 Rears? RonB352 Wheels, Tyres & Brakes 0 Jun 5th, 2007 09:43 PM
Mix 215/35/18 Rears w/205/40/18 Fronts? RonB352 Wheels, Tyres & Brakes 4 Mar 30th, 2007 04:47 PM
Privacy Rears Vs Standard Fronts wibbly First Generation MINI Exterior 13 Jul 25th, 2005 08:53 PM
Just had my first new fronts at 11k miles. miikkg Wheels, Tyres & Brakes 1 May 16th, 2005 05:30 PM
those fronts need replacing Sc00bster Wheels, Tyres & Brakes 4 Jun 8th, 2004 09:45 AM
