17x7 ET40 with 205/45's and lowered, any rubbing? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jan 13th, 2005, 07:51 AM
maxdude's Avatar
Local Time: 03:28 AM
England View maxdude's Classified Ads
New rims going on soon. 7x17 ET40 with 205/45's. Have lowered on eibachs, 30-40mm. I am hoping this set up will not cause me any rubbing. Does any one else have similar set up? Problem free?
Superchip-Pipercross Indution-Eibachs-Whalen-S2000 Starter Button-Janspeed Cat Back and Manifold,-Colour Coding-Konig E Racers 17"
Old Jan 14th, 2005, 02:54 PM
maxdude's Avatar
Ok, nobody knows?? I have made some rough calculations and from what I gather the tyre sidewall will protrude out an extra 15mm (10mm extra for offset and extra 5mm for width of tyre), therefore becoming increasingly closer to wheel arch. If the tyre is shaped curved (like it is now) rather than square (if that makes sense), plus the fact that I will also be losing a few mm in overall diameter so will be marginally lower beneath the wheel arch. All this considered, then I don't think I will have a problem, especially at the front. It is the rear that concerns me more. Any clarification of this would be gratefully received, and confirmation if I am on the right lines here, cause this is rather technical for me! If not, I guess it will be just a case of try it and see, and hope for the best!!
Old Jan 18th, 2005, 09:49 PM
KGB's Avatar
KGB
Local Time: 02:28 PM
Australia
I'm running 17 s-spokes and Eibachs, no rubbing...just grinning....
Old Jan 19th, 2005, 12:56 PM
KATENKEITH's Avatar
Challenge addict ...still
Local Time: 04:28 AM
England
we`ve got 215-45`s on Fox 3 17" alloys on a standard MC and they occasionaly rub on the rears when there are passengers in. Its not bad but I`d go for 205`s rather than 215`s next time . Not a lot of help i know but I wonder if anybody else has the same problem with 215`s?
Old Jan 19th, 2005, 01:50 PM
maxdude's Avatar
Thanks you 2. I think i'd be ok with the 205's.
Will a 17x7.5 ET40 (4x100PCD) wheel fit a UK Mini cooper ? Quads Wheels, Tyres & Brakes 6 Feb 14th, 2007 06:46 PM
HELP! lowered 20mm with Eibach's now got rubbing.. what are my options?? john_cook First Generation Faults & Fixes 13 Oct 31st, 2005 07:47 AM
Will 225/45ZR17 Azenis fit without rubbing on my lowered MCS? VWY Wheels, Tyres & Brakes 4 Jun 14th, 2005 05:58 PM
205/50 17...rubbing issues with this size? sergio rollerfunk Wheels, Tyres & Brakes 1 Dec 8th, 2003 05:08 AM
205/40/17 on 17x7 et45's wness Wheels, Tyres & Brakes 5 Apr 5th, 2003 01:15 AM
