Tyre foam - non-run flats - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jan 26th, 2005, 01:26 PM
wildchild jules's Avatar
Now answering to Lady J!
Send a message via MSN to wildchild jules
Local Time: 04:29 AM
United Kingdom Female View wildchild jules's Hyper Blue & White 1st Gen MINI Cooper S Profile
Sorry to be a bit of a girl here but don't know what this foam stuff is that you put in tyres if you don't have run flats. Can somoene explain what it is/how does it work etc. I have a horrible vision of it being very messy!
I am currently driving on run flats (and will be for some time as picking up a new MCS on 1st March) but was interested to know about this foam and how effective it is should I decide to go down the no run flat route when my tyres need changing.
thanks!
Old Jan 26th, 2005, 01:41 PM
Quote: Originally Posted by Max
It "repairs" the puncture from the inside. Not messy for you, but very messy for the technician who ends up cleaning the tyre fitting machine
thanks! That's what I was thinking, once you get the car to the garage it must very messy for them to then deal with the puncutre! Can they still mend it after you have used foam? do they get a bit stressy about the mess if you have used foam?
Also, would you need to use a whole can of this foam each time you had a puncture? I really don't know much about this foam, hence all the questions!!!
Old Jan 26th, 2005, 01:59 PM
scooperman_uk's Avatar
almost 59k
United Kingdom View scooperman_uk's Solid Black & Body Color 1st Gen MINI Cooper S Profile
wont repair a damaged tire wall tho. also depends on the size of the puncture too, these were designed for a slow puncture where u want to plug a small whole rather than fix a serious tire problem. stick with runflats. ok they are expensive but im experience invaluable. for example i got a puncture in central london on a sunday morning MINI run last year. i was able to finish the run and drive back home without needing to get the tire replaced, if i hadnt have got a runflat my day would have been very different........
Run flats versus non-run flats tceditor Wheels, Tyres & Brakes 10 Apr 26th, 2006 09:49 AM
Tyre sealant system rather than run flats Westy Wheels, Tyres & Brakes 6 Apr 8th, 2006 12:45 PM
Replacing run flats with non run flats? minifrog Wheels, Tyres & Brakes 2 Oct 24th, 2003 04:14 AM
Buy New Run Flats or a Wheel & Tyre Package jon.od Wheels, Tyres & Brakes 3 May 27th, 2003 02:55 AM
Tyre wear on run flats bradg Wheels, Tyres & Brakes 6 Nov 3rd, 2002 02:45 PM
