The only way it's an issue is if you have to change tire like I do. One side at a time.
I have a steep gravel driveway so it's a bit unsafe for jacking so I have to do mine in the street.. I change one side and then drive the car enough to turn it around and park oposute side to the curb. Then change the other side.
Usually this triggers the warning light about 3-4 miles down the road next time I drive. Especially since I always forget to try the reset as soon as I'm done swapping tires
If you can do all 4 tires at once it isn't a problem. At least it hasn't been for me the couple times I could do it that way.
I swap tires regularly for auto-x.
