Background: I've got some 205/55/16 Toyo R1R semi-slicks on some el cheapo rims. I've got some -2 to -3 deg of neg camber up the back end, running stock SS+ shocks, lowered springs and front/rear beef'ed up sway bars.
Problem: front and rear both set at 33psi, the front remains the same YET the rear rises up to 37-38psi even. I know when tyres are set at the correct tyre pressure there shouldn't be enough heat generated to cause the rise but if I do set it to 37psi, the rear tyres are still going up to 41psi even after a short drive.
On the other hand, I've also tried dropping it down to 27psi for the rear but it doesn't take too long before they come back to 35psi. What's happening?
Thanks in advance
