lowered & stiff - tyre wear - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Apr 9th, 2005, 04:43 PM
GTT 280's Avatar
The Power Cube
Local Time: 04:30 AM
United Kingdom View GTT 280's Classified Ads
England lowered & stiff - tyre wear
Can anybody explain to me why people say that tyre wear is more noticable with lowered and stiffened suspension?
Is it to do with the abruptness of the shock and increased force behind the wheel and tyre?
And is it to do with the increased camber angle and side wear?
Old Apr 9th, 2005, 05:36 PM
Local Time: 10:30 PM
lower / stiffer suspensions allow higher corner speeds, which loads up the tires more and wears them out faster. Camber control should be better since the suspension will deflect less, but you'll also need to run slightly more negative camber due to the higher corner loads and more tire deflection. If you don't, the outside edges of the tires will wear faster then the inside, provided you don't drive like my grandmother.
The rear end should add more negative camber when lowered, the front will gain positive camber when lowered. You'll need to find some more adjustment in the front or you won't have enough negative camber even though you may still be within spec. There should be adjustment in the rear to correct the too much negative camber, if not, you'll need to get a set of adjustable links.
BTW:
Negative Camber = tops of tires lean in
Positive Camber = tops of tires lean out
Tyre Wear martyn peters Wheels, Tyres & Brakes 1 Sep 21st, 2007 05:29 PM
Tyre Wear KillerByte Wheels, Tyres & Brakes 1 Jan 27th, 2007 01:51 PM
Tyre Wear Hugo Wheels, Tyres & Brakes 3 Aug 28th, 2006 07:53 PM
Fault with some minis BMW won't admit- Rapid & uneven tyre/tire wear Geese First Generation Faults & Fixes 1 Dec 20th, 2004 01:12 PM
Tyre Wear pmr01 Wheels, Tyres & Brakes 5 Apr 4th, 2003 08:04 AM
