Adam's Polishes
Old Apr 15th, 2005, 01:43 AM   #1
tricky
tricky
tricky's Avatar
Local Time: 08:32 PM
United-Kingdom what size wheels?
using 175/65-15 tyres and wheels very smooth ride but boring ...may change to 205/45-17 white is it worth it? heard it affects speedo and comfort..any ideas ta!
Old Apr 15th, 2005, 02:00 AM   #2 (permalink)
haroldchrismeyer
Local Time: 03:32 PM
You will lose tire sidewall when you go to the 17 inch wheels, which makes the car handle better, This is offset by a harsher ride. If the outside of the tire diameter stays the same, then the speedo will not be affected. Find someone with 17 inch wheels and go for a ride.
Old Apr 15th, 2005, 10:29 PM   #3 (permalink)
tricky
tricky
tricky's Avatar
thanks for that ....its more or less what i thought i guess a harsher ride it is
17 wheels - Offset and Spigot size philipnslater Wheels, Tyres & Brakes 5 Oct 4th, 2007 01:15 PM
Best size tyres for 17" wheels CapeTownDre Wheels, Tyres & Brakes 1 Jul 13th, 2006 01:16 AM
size differance 17,18,19"wheels marcy Wheels, Tyres & Brakes 2 Jan 29th, 2006 12:14 AM
What size wheels do you have on your Mini? MiniMan7 Wheels, Tyres & Brakes 15 Jan 17th, 2003 09:17 PM
Cars that use the same size wheels?? scottgib MINI in Motorsport 4 May 26th, 2002 05:22 PM
