runflat tyre pressures - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old May 27th, 2005, 09:33 AM
death2pixies's Avatar
GP0722 and Cooper S
Send a message via MSN to death2pixies
Local Time: 04:31 AM
United Kingdom Female View death2pixies's Thunder Blue & Silver 1st Gen MINI Cooper S JCW GP Profile
Question runflat tyre pressures
Hi All
I've done a search but can't see what I am looking for. Can anyone tell me what the correct tyre pressure is for Eurofori@ runflats. I had them at 2.3 bar (34psi) and I have been skating all over the road. I've taken them down to 2.2 bar (32psi) but what is the correct pressure? i have a lot of driving over the next couple of weeks and want to try and get it right
many thanks
Old May 28th, 2005, 09:31 PM
KingCoopah's Avatar
Send a message via AIM to KingCoopah Send a message via MSN to KingCoopah Send a message via Yahoo to KingCoopah Send a message via Skype™ to KingCoopah
Local Time: 11:31 PM
I've been running my OEM Run flats at about 42 PSI. The Good Years I have say 55 PSI Max cold. So I figured that tires tend to gain about 10 PSI when driving them. So 42 PSI would be a nice good number if you like a STIFF RIDE. If you want a smoother ride then go with about 32 - 35 PSI. OF COURSE it all depends on what tires you have AND check the tire it self for the Tire Pressure. In tires that take more than 35PSI always guess about 5-10 psi LOWER than max. Use your discretion.
Old May 28th, 2005, 09:43 PM
MINIAC's Avatar
Canned
Local Time: 08:31 PM
Your owners manual should contain recommended tire pressures.
US cars also have tire pressures listed on the driverside door jam.
42 PSI is way too high
Old May 28th, 2005, 11:38 PM
BOCCIE's Avatar
PIRKO
Local Time: 12:31 AM
Argentina View BOCCIE's Dark Silver & Black 1st Gen MINI Cooper S Profile
Quote: Originally Posted by death2pixies
Hi All
many thanks
Correct PSI for MCS Eufori@ Run Flats is 2.3 or 2.6 Bar depending on the load of the vehicle.
There is a very interesting brochure from Pirelli on the Eufori@s which could be downloaded from :
pirelli's site , go country UK and click on the run flats where there is a PDF with all the specs.
After reading it youŽll also realize something not to many people knows about run flats and it is that after running them flat they must be replaced, yes you read it well REPLACED... Hope this covers your question.
Tyre Pressures CC07ERS Wheels, Tyres & Brakes 2 Apr 20th, 2007 07:34 PM
Tyre Pressures saint12661 Wheels, Tyres & Brakes 2 Jun 29th, 2006 10:36 PM
Tyre pressures MarkW19 Wheels, Tyres & Brakes 4 Jan 23rd, 2006 06:00 PM
MSC Runflat pressures v ride comfort JohnWB Wheels, Tyres & Brakes 0 Sep 7th, 2005 12:35 PM
tyre pressures amandachannon Wheels, Tyres & Brakes 4 Jun 21st, 2005 08:52 PM
