Rear wheel alignment question - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jul 20th, 2005, 05:26 PM
Local Time: 10:32 PM
Can the rear wheels be aligned properly, after lowering the car, without adjustable camber links?
Old Jul 22nd, 2005, 08:33 AM
Lohen's Avatar
Send a message via Skype™ to Lohen
Local Time: 04:32 AM
You cant really do it...
You can adjust the toe with just the standard parts. BUT If you wanted to change the camber however on the rear wheels then you would have to get adjustable control arms. This is mainly because both of these are adjusted via a different part.
Andrey
MCS Wheel Alignment in Sydney - a question mmilgrom Australia 7 Oct 25th, 2007 04:18 AM
Wheel Alignment Kim Prior General Discussion 6 May 3rd, 2007 09:06 PM
Wheel alignment myspeed First Generation Faults & Fixes 24 Apr 29th, 2007 03:08 PM
Wheel alignment help Grezza Wheels, Tyres & Brakes 7 Mar 12th, 2007 12:05 PM
wheel offset and wheel alignment george p Wheels, Tyres & Brakes 3 Jun 30th, 2006 06:58 AM
