tire pressure????? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Sep 2nd, 2005, 07:23 PM
Send a message via AIM to gregc
Local Time: 11:33 PM
United-States tire pressure?????
I'm running Goodyear Eagle NCT 5 195/55R16 H rated run flats on my '05 Cooper. The plackard on the door says '35PSI; the manual states for this tire size, 1 to 4 passengers, under 100MPH 30lbs; over 100MPH 35 PSI. Should I use the 35 or 30 PSI for normal driving? It seems odd thet the door plackard would not match the manual for normal driving.
gregc
Old Sep 3rd, 2005, 03:52 AM
CHD's Avatar
CHD
S Xpress
Local Time: 08:33 PM
United States View CHD's Chili Red & White 1st Gen MINI Cooper S Profile
gregc
Anywhere from 30-35 will be fine.
30 will be grippier, but give you more wear on the shoulders of the tire over time.
35 Will be less grippy, probably give you better gas mileage, and wear the center of the tread 1st.
And don't forget to measure the pressure cold - not during a journey when the tire is hot!
Chris.
Was: 02 MCS - DS/BL - Alloy Patina - Half Leather - Mille Miglia 18" Alloys - Toyo 235/35/18 Rubber
Now: 03 MCS - CR/WH - Anthasite Dash - Leather - White 18" Exel TZ-10 Alloys - Union Jack Roof Decal - K&N Typhoon - XM Direct
tire pressure carguy54 Wheels, Tyres & Brakes 1 Apr 20th, 2004 11:39 AM
Tire Pressure? flatsix02 Wheels, Tyres & Brakes 10 Dec 16th, 2003 10:04 PM
Tire pressure ice Wheels, Tyres & Brakes 8 Jun 19th, 2003 10:49 PM
Tire pressure? K-Rog First Generation MINI Tuning 3 Aug 2nd, 2002 10:09 AM
