Oil Starvation, Engine Seizure, Warranty Wrangle - Page 2 - MINI Cooper Forum
Dealership Feedback Discuss your experiences with MINI dealers worldwide
post #16 of 19 (permalink) Old Mar 24th, 2011, 07:50 PM Thread Starter
Local Time: 12:43 PM
Revchap ...
Dude I'm so sorry I've only just seen your post from Nov 2010, came back on the site because I received a friend request today from someone with the same issue...I hope you got your problem sorted but please let me know if you're still looking for advice and please accept my apologies for apparently ignoring your request for help..
Last edited by MINIAC; Mar 24th, 2011 at 08:45 PM. Reason: Merge consecutive posts
bobako74 is offline
post #17 of 19 (permalink) Old May 18th, 2015, 12:58 AM
Registered User
Quoted: 1 Post(s)
My 2008 and 2010 have both consumed a quart of oil every 750 or so miles. Yes, the oil stick is a pain. You need to have good light because what you are looking for is two things. . . the dot near the pointy end should be full of oil and not reflecting back any light. Secondly, there is a "pebbly" surface on the rubber part. If you can see the texture, there is no oil on it. Sometimes there will be oil on one side but not all of the way around. Wherever you see pebbly surface at the lowest point on the stick is where the level is.
I have one valve that started clacking regularly after BMW replaced my whole timing assembly for the second time. Someone said it is probably a warped valve (or. . piston?). I know nothing about engines. If someone could give me an opinion on this, and whether I should consider trading in my car (which I love) before my 100k warranty wears out, I would appreciate it!
Heaven is offline
post #18 of 19 (permalink) Old Jun 8th, 2015, 06:18 PM
RDD
Quoted: 5 Post(s)
Last post March 2011
RDD is offline
post #19 of 19 (permalink) Old Mar 30th, 2017, 07:46 PM
Registered User
Not all cars burn oil. These are by far the worst I've ever encountered. My 1974 Chevy Vega would use a quart at 1000 miles like clockwork. I think that engine had a design award back then too. This one gets about 500 miles on a quart. I check it every week for usage. I'm thinking of changing the turbocharger as it looks damp by the waste gate.
THE BEST car I've had is a 1985 VW Jetta. That never used a drop with over 400,000 miles on it.
Brian B is offline
Tags: , , , , ,
Oil Change Voids Warranty frails Maintenance & MINI Care 47 Apr 4th, 2010 06:34 PM
do i need to change oil filter when changing engine oil? asinn Maintenance & MINI Care 6 Jan 27th, 2005 04:20 PM
Fuel Starvation Problem NearlyNN MINI in Motorsport 18 Mar 25th, 2004 02:40 AM
Oil starvation in turns chiph MINI in Motorsport 13 Jul 24th, 2003 04:03 PM
changed my engine oil and oil filter today :D erichui Maintenance & MINI Care 15 Dec 23rd, 2002 08:56 AM
