Strong smell of petrol..... - MINI Cooper Forum
post #1 of 7 (permalink) Old Dec 18th, 2007, 09:01 PM Thread Starter
Ven0m's Avatar
Local Time: 06:28 PM
Over the last few months I have noticed a very stong smell of petrol when removing the oil cap
Any ideas guys??
Ven0m is offline
post #2 of 7 (permalink) Old Dec 18th, 2007, 10:19 PM
MINI & other both whine
Randall Raines's Avatar
Local Time: 05:28 PM
Any ideas guys??
Possible cylinder-head gasket?, possible piston rings? could be a couple of other possibilities .
Its definitely in the oil though & you're not just getting a smell of petrol as you go to do the oil as the fuel pipe connects to the engine at the front under your inter-cooler (little rad) on Ss or a plastic panel on COOPERs / ONEs (DIESELS are totally different).
I don't want to worry you but I have seen plenty of MINIs that have had under bonnet fires , so I would make sure it's not leaking fuel ASAP!.
Destined to live life 5 behind. Disclaimer Any advice given is my opinion only, if you decide to act on any advice / info I've given, it's at your own risk!
Randall Raines is offline
post #3 of 7 (permalink) Old Dec 19th, 2007, 02:05 PM Thread Starter
Ven0m's Avatar
Thanks for reply...
Its deffinately coming from the oil cap and inside....
A friend sugeested that the car maybe running to lean which might of caused a failure of some kind.
Ven0m is offline
post #4 of 7 (permalink) Old Dec 19th, 2007, 03:51 PM
Thanks for reply...
It's hard to suggest things on here, it will be a failure of some sort, but it will be an internal one (unless you have been putting petrol in the oil filler-cap , sorry!), so it could be hard to pinpoint, and very hard without doing checks, so I would have a mechanic (someone you trust & who knows what they are doing ) to have a look at it before it ends up worse or at worst case scenario in total failure .
post #5 of 7 (permalink) Old Dec 19th, 2007, 05:19 PM Thread Starter
Ven0m's Avatar
Petrol in the oil fillier-cap......
Yeah im booked in with GTT this friday so hopefully all will be running properly again soon.
Ven0m is offline
post #6 of 7 (permalink) Old Dec 30th, 2007, 10:03 PM
Send a message via MSN to fraindog
ive just noticed my car puffing white smoke on startup..had a smell and it stinks of petrol..turned the engine off just incase and had a look under the bonnet just to have a check if theres anything visable.. and my oil cap also smells of petrol.
its raining out so i cant really see if its leaking petrol...any ideas
thanks
chris
fraindog is offline
post #7 of 7 (permalink) Old Dec 30th, 2007, 10:55 PM
Local Time: 01:28 PM
United States Male
Any ideas guys??
And you have been removing the oil cap because....? I know of no reason the inside of the crankcase would smell like unburned fuel. You should look around the engine compartment to see where the smell is coming from, but its not from under the oil cap.
oldmots is offline
Fume/"Old Engine" smell at stand still Blusox First Generation Faults & Fixes 7 Apr 16th, 2017 07:57 AM
2001 Mini Cooper - Lost petrol cap caffelatte1 First Generation MINI Exterior 5 Nov 4th, 2012 09:08 AM
Petrol Smell Coming From Engine Bay SamPowell Second Generation Faults & Fixes 1 Aug 12th, 2012 06:43 PM
2007 MCS juddering after filling up with petrol. LadyUK Second Generation Faults & Fixes 3 Aug 12th, 2012 06:03 PM
