passenager door doesn't open on the remote or in side on the button? - MINI Cooper Forum
post #1 of 10 (permalink) Old Feb 20th, 2009, 07:32 PM Thread Starter
Local Time: 01:59 AM
United-Kingdom passenager door doesn't open on the remote or in side on the button?
this has only just happened?
any help would be good,
thanks jack
jackscoopers is offline
post #2 of 10 (permalink) Old Feb 20th, 2009, 08:32 PM
Unlocking mode
You can also set which parts of the car are
unlocked. The setting is stored for the remote
control in use.
1. Switch on the ignition, refer to page 35.
2. Briefly press the button in the turn indicator
lever repeatedly until "SET/INFO" is displayed.
3. Press and hold the button until the display
changes.
4. Briefly press the button repeatedly until the
symbol and "SET" are displayed.
5. Press and hold the button until the display
changes.
6. Briefly press the button repeatedly until the
display shows the illustrated symbol, arrow.
7. Press and hold the button until the display
changes.
8. Briefly press the button to select:
Press the button once to unlock
only the driver's door and the fuel filler
door.
Press the button twice to unlock the
entire vehicle.
the entire vehicle.
9. Press and hold the button until the display
changes. The setting is stored for the remote
control currently in use
Does this help?
Dreboy is offline
post #3 of 10 (permalink) Old Feb 20th, 2009, 09:13 PM
MINI2 No.1
Paul's Avatar
Quoted: 1 Post(s)
England Male
Send a message via Skype™ to Paul
What age MINI do you have, first or second generation?
Paul is offline
post #4 of 10 (permalink) Old Feb 20th, 2009, 09:20 PM
scraggles's Avatar
Local Time: 12:59 AM
United Kingdom Male View scraggles's Pure Silver & Body Color 1st Gen MINI One Profile View scraggles's Classified Ads
thanks jack
I had a similar problem with my drivers side door. Something like the solenoid in the lock mechanism failed. It would open with the key and handle, or the inside handle, but unlocking from the key remote or dash switch wouldn't work
If this is the problem, It's a common one and requires the Rotary Latch Lock needs to be replaced.
They're £50 - £60 plus fitting. Mini Mania stock them and there's also some listed up on eBay.
scraggles is offline
post #5 of 10 (permalink) Old Feb 20th, 2009, 10:06 PM Thread Starter
it doesn't have a button on the indicator.how do i program it with out this?
post #6 of 10 (permalink) Old Feb 20th, 2009, 10:09 PM Thread Starter
first generation?
post #7 of 10 (permalink) Old Feb 21st, 2009, 06:52 AM
MINI2 No.1
Paul's Avatar
Quoted: 1 Post(s)
England Male
Age would tell us, which is why I asked both. I'm guessing first gen just by the nature of the fault.
Paul is offline
post #8 of 10 (permalink) Old Mar 1st, 2009, 09:39 AM
Cooper Dooper!
Ours doing the same, 53reg Cooper
Hello all, we've just bought our Mini from a Porsche dealer in Biggin Hill, it came with a 12 month independent warranty as the TLC pack has expired (although we do have two vouchers in the book), the car is more than 5 years old, so i assume that TLC is finished? The car is only on 28K miles however.
We've tried pressing the Mini emblem twice on the fob and the passenger door just won't open. The only method for opening is with the interior handle.
We also don't have the button on the indicator stalk (for the computer?), so cannot follow the good advice above. Do we therefore need to hook up a BMW computer to tweak the setting or is there another way?
When we do attempt to unlock the doors, i can hear the motor in the door, but the pull button does not lift and the door remains firmly closed.
Thanks for any help offered.
ChalkyWhite is offline
post #9 of 10 (permalink) Old Mar 5th, 2009, 01:35 PM
rec
rec's Avatar
England Male View rec's Classified Ads
the instructions above is to configure the central locking system when you press the button on the key fob.
if the door doesn't open at all regardless of the amount of times you press the unlock button, or press the switch on the dash, i'd say the solenoid in the door is dead.
rec is offline
post #10 of 10 (permalink) Old Mar 6th, 2009, 02:33 AM
MINI on the brain!!!
85NIXMIN's Avatar
Local Time: 10:59 AM
Australia Female View 85NIXMIN's Midnight Black & Silver 2nd Gen MINI Cooper S Profile
This happened to me a few months ago... Passenger side door wouldn't open with 2nd press on my key....or from inside when flicking the toggle... It ended up being the actuator....$250 later and it was fixed... Mine is a 2003 MINI COOPER! Hope that helps!
03 BLACK MC, 05 BEP MCC, 07 BLACK MCS, 09 PW MCSC, 12 MB MCSCoupe
85NIXMIN is offline
