GearBox problems - MINI Cooper Forum
 2Likes
  • 1 Post By minione2002
  • 1 Post By mike1967
post #1 of 10 (permalink) Old Oct 28th, 2017, 06:53 PM Thread Starter
Local Time: 03:03 PM
Quoted: 1 Post(s)
GearBox problems
Hi
Does anyone know what my problem is, I have bought a 2003 cooper and it is making a noise when in gear and speeding up and slowing down. it only makes noise while moving and in every gear 1 to 5.
It will go away when I press the clutch in and coast and it also doesn't make any noise while idle. The noise also gets faster with acceleration.
could this be the thrust bearing or something else?
I also found this video on the tube which sound very similar.
youtube.com/watch?v=rC7UZY-ylJU
Thanks for any help.
blips is offline
post #2 of 10 (permalink) Old Dec 10th, 2017, 10:36 PM
Grease Magnet
lewheel's Avatar
Quoted: 4 Post(s)
Australia Male
Garage
I'm afraid I had the same problem, and I know there are others. We're all victims to the Midlands gearbox which comes standard with most first generation Coopers (they were upgraded after 2004 I believe). When my Cooper was in gear it'd get a terribly loud whine, and the whine would rise/fall in pitch as you were accelerating/decelerating, respectively.
I believe you can eliminate the thrust bearing as that would be more likely to give noise during the motion of pushing the clutch in. The source of your problem is likely to be the bearings inside the gearbox. My money's on either the input shaft bearings or the differential bearings. Not wanting to pull my gearbox apart, I replaced my whole unit with a 6 speed gearbox from a Cooper S. Worth every dollar, but it's a bit of effort and requires other parts. I recommend having a mechanic listen to the noise and give you a solid second opinion on the noise before taking action - transmission work can be pricy.
lewheel is offline
post #3 of 10 (permalink) Old Dec 11th, 2017, 12:54 PM
Quoted: 631 Post(s)
Originally Posted by blips View Post
Hi
common problem will be both diff and both gear shafts end bearings made of chocolate vauxhall gearboxes do same trick
https://www.ebay.co.uk/itm/BMW-MINI-...AAAMXQ6DBSDlD~
the above link best option as secondhand gear boxes are normally not far off going same way..
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is online now
post #4 of 10 (permalink) Old Dec 11th, 2017, 09:52 PM
Moderator
minione2002's Avatar
Quoted: 625 Post(s)
As said above the Midlands bearings are made of cheese.
The gertag 5spds introduced in july 2004 weren't much better tbf.
Contact John Tee Gearbox specialists, they are r65/Midlands gearbox specialist in the UK
their prices are very reasonable for a full recon/rebuild
mike1967 likes this.
minione2002 is offline
post #5 of 10 (permalink) Old Dec 12th, 2017, 06:02 PM
Quoted: 631 Post(s)
there prices are very reasonable for a full recon/rebuild
by far the best way forward for non do it yourself repair
minione2002 likes this.
post #6 of 10 (permalink) Old Dec 16th, 2017, 09:13 AM
Quoted: 1 Post(s)
Hi. I had a similar problem with my mini. Would be a good option to try upgrade the gearbox to the getrag 5 spd or 6 spd from the s.
Only problem is the cost that it may incur. John tee is amazing used him earlier this year for gear box change. Very quick service and good guy withe low price.
A link to my post.
https://www.mini2.com/forum/first-gen.../topics/332617
Sent from my iPhone using Tapatalk
PepsiSingh is offline
post #7 of 10 (permalink) Old Dec 17th, 2017, 09:11 AM
cristo
cristo's Avatar
Local Time: 11:03 AM
Quoted: 37 Post(s)
United States Male View cristo's Hot Chocolate & Silver 2nd Gen MINI John Cooper Works Clubman Profile
Garage
I did the 6 speed swap on my 2003 MINI Cooper a few years
ago when my Midland's differential bearings started making a
helicopter noise on acceleration and engine braking.
Took a bit of time and money, but I'm glad I did it.
Put a Quaife LSD in the 6 speed Getrag box as well.
cristo is offline
post #8 of 10 (permalink) Old Dec 17th, 2017, 03:11 PM
Quoted: 631 Post(s)
always fancy'd putting a 6v turbo engine and diff in the back of a clubman as a project. ie mitsubishi fto engine with a super charger conversion would be mental as they go so well from standard with a tiptronic box,, years ago we would do all kinds for shoe horns, hillman imp with rs2000 pinto engine hanging out the back would pull wheelies. loads of mk1 and mk capris with rover v8',, dolomite sprint with rover v8 was the biggest nightmare it really dont want to fit.. even but a alfa romeo alfa sud 1.5tb engine and box in to a datsun 100A cherry that was deadly . the things 30 years ago or more you could legally build and insure..
my point was most of these engines and mixture of gearboxes you could buy off shelf conversion plates that allow different makes gearbox to fit others engine blocks,, someone should come up with one for the later gearbox to fit the early cars maybe
post #9 of 10 (permalink) Old Dec 17th, 2017, 04:16 PM
Sour Mash
Jackdaniel's Avatar
Quoted: 342 Post(s)
Garage
What about a 46 litre engine
https://m.youtube.com/watch?v=wJn7LHE83cc
2002 Mini Cooper R50, purchased Nov 2016
Jackdaniel is online now
post #10 of 10 (permalink) Old Dec 18th, 2017, 01:21 PM
Quoted: 631 Post(s)
m5 v10 engine would be the one but would struggle with wheelbase of clubman by time added a gearbox i would think,,
Diff / gearbox noise?? PepsiSingh First Generation MINI Cooper 18 Nov 21st, 2017 02:58 PM
The midlands/r65 gearbox - Gertag 5spd issues. minione2002 First Generation Faults & Fixes 17 Nov 2nd, 2016 02:38 PM
r53 JCW Gearbox, Limited Slip Differential luckylew1991 First Generation Faults & Fixes 12 Apr 10th, 2016 11:52 PM
Midland Gearbox repair help jobforacowgirl First Generation Faults & Fixes 11 Sep 29th, 2015 04:11 PM
