03 mini cooper fuel gauge not reading - MINI Cooper Forum
 1Likes
  • 1 Post By JohnnyC
post #1 of 7 (permalink) Old Apr 16th, 2018, 10:50 AM Thread Starter
Local Time: 11:53 AM
Hi, as title says I'm having some issues with fuel gauge on my mother's mini. I have read through online research and haven't came up with anything solid so I'm hoping someone can help me.
Fuel gauge is on the red led, range reads ---. I have done a dash reset, didn't help, I have stripped rear interior out to check the wires coming from the outside into the car and checked the earth connector there for corrosion, it's fine, pulled the covers off the tank and checked plug and wiring, ok.
When I use the dash test mode 6.0 is reading 08454, 6.1 is reading 00332 and 6.2 is reading --000 with a 3 for implausible signal.
Am at my whits end with this so any help is appreciated!
Thanks in advance
Sk3ltan is offline
post #2 of 7 (permalink) Old Apr 16th, 2018, 11:22 AM
Local Time: 12:53 PM
Quoted: 121 Post(s)
Break in the earth for the side which 6.2 represents. There’s a crimp joiner in the passengers footwell.
k3fus is offline
post #3 of 7 (permalink) Old Apr 16th, 2018, 11:37 AM Thread Starter
In the passenger rear footwell? Under the carpet? If so that's the earth connector I've checked and it's fine 😥
Sk3ltan is offline
post #4 of 7 (permalink) Old Apr 18th, 2018, 08:30 AM Thread Starter
Anymore help on this issue??
Sent from my SM-G935F using Tapatalk
Sk3ltan is offline
post #5 of 7 (permalink) Old Apr 18th, 2018, 08:34 AM
minione2002's Avatar
Quoted: 625 Post(s)
Garage
fuel level senders can go on the Pish..
Only problem is it's part of the fuel pump!
And not cheap..
@JohnnyC had this issue except it was faulty on a new pump!!
minione2002 is offline
post #6 of 7 (permalink) Old Apr 18th, 2018, 11:15 AM
JohnnyC's Avatar
Quoted: 244 Post(s)
United Kingdom Male View JohnnyC's Classified Ads
And not cheap..
From what I remember, you can buy the fuel level sender without the pump, but you can't buy the pump without the level sender. Which is good
Removing fuel pump is quite straightforward
minione2002 likes this.
JohnnyC is offline
post #7 of 7 (permalink) Old Apr 23rd, 2018, 10:27 AM
Hi all
I've got a issue with my 2004 Mini regarding the fuel gauge. Sometimes it will show 4 yellow lights then other times it will just jump to the red empty light. I was wondering if you guy's could help me out. I had it plugged into the diagnostics and it came up with tank sensor 2. I was told this was the one attached to the filter so changed the whole unit. This didn't solve the problem and so I changed the other level sensor on the pump as well but still have the same problem. As you can imagine costs are mounting and would really appreciate your help on this matter.
Regards
Cooperone
Cooperone is offline
Fuel Gauge Reading Empty When Tank Is Full ??? kshapiro First Generation Faults & Fixes 12 Feb 18th, 2016 10:41 AM
'03 MCS - Dodgy Fuel Gauge CJGREEN89 First Generation Faults & Fixes 1 Dec 17th, 2015 03:32 PM
Fuel gauge reading k3yyx First Generation Faults & Fixes 2 Apr 3rd, 2012 11:23 AM
Fuel Gauge Reading DMBMini Second Generation MINI Cooper 2 Oct 4th, 2009 05:31 AM
Unbelievable. Car goes into the dealers because the temp gauge is over reading... Root Ginger General Discussion 13 Feb 3rd, 2006 12:35 AM
