Fuel level & Starting Problem - MINI Cooper Forum
post #1 of 6 (permalink) Old May 20th, 2019, 03:25 PM Thread Starter
Local Time: 05:17 AM
Hi i replaced the fuel filter on my 04 Cooper and now car hesitates while starting and it doesnt start on first crank.
Fuel gauge reads wrong,fuel tank was empty but fuel gauge showed like quarter tank.
MadMuzo is offline
post #2 of 6 (permalink) Old May 20th, 2019, 10:55 PM
knt
Local Time: 02:17 AM
Quoted: 52 Post(s)
Have a look here and see if you've missed anything.
https://www.pelicanparts.com/techart...eplacement.htm
http://www.billswebspace.com/MiniR50...erDIYGuide.htm
knt is offline
post #3 of 6 (permalink) Old May 21st, 2019, 07:41 PM Thread Starter
I think i did everything correct i double checked but i could disconnected something out of float assembly or wires.
Or could this be a bad fuel pump but car wasnt doing this things before.
PS I am using the Vaico filter
MadMuzo is offline
post #4 of 6 (permalink) Old May 21st, 2019, 10:22 PM
knt
Quoted: 52 Post(s)
What was wrong with the car before you replaced the parts?
Did you have a diagnostic scan of the car?
knt is offline
post #5 of 6 (permalink) Old May 22nd, 2019, 12:47 AM Thread Starter
Nothing was wrong i just wanted to replace the fuel filter. Diagnostic scan shows 0 issues.
MadMuzo is offline
post #6 of 6 (permalink) Old May 22nd, 2019, 09:30 AM
knt
Quoted: 52 Post(s)
Does the fuel guage still reads wrong capacity or does it read correct with some fuel in?
I would recheck the install you've done as you might have not connected some of the electrical connector and/or hoses properly.
knt is offline
Weird starting problem / FUEL PUMP, FILTER ? Schakal General Discussion 0 Oct 31st, 2013 10:55 AM
Cooper S 2002 Starting problem & Fuel Smell Dasch First Generation Faults & Fixes 2 Feb 2nd, 2011 09:43 PM
Fuel light and volume of fuel in fuel tank atnova First Generation MINI Cooper S 9 Nov 24th, 2009 01:18 AM
Coolant level right on min level rainbowdreamer First Generation Faults & Fixes 2 Aug 24th, 2003 04:06 PM
