OBD2 port wiring - Page 2 - MINI Cooper Forum
First Generation Interior & Ice
 1Likes
post #16 of 21 (permalink) Old Dec 20th, 2017, 08:46 PM
Local Time: 07:54 AM
Quoted: 119 Post(s)
All cars cause problems, it’s worth sticking at it though. I agree how can they have traced the wire if they didn’t break in to the loom. Check and junctions or bulges for connections or breaks. I flunked finding mine, but checked a bulge and the issue was obvious.
k3fus is online now
post #17 of 21 (permalink) Old Dec 21st, 2017, 07:45 AM Thread Starter
Jonny-english's Avatar
Local Time: 06:54 AM
Quoted: 55 Post(s)
Garage
Yea that's what i'm hoping, i do find it strange though that 5 garages have checked the wiring supposedly and said there is nothing wrong. What i want to do over the holiday is check the entire length of cable and also disconnect the modules attached in the image (circled in manly pink). If I have the locations of them and what I need to do that would be great! As a side note I have changed the dials (instrument cluster) as everything to the left of the dials is fine.... everything to the right cannot be connected to, seems logical but didn't work
thanks again guys,
Jon
Name:	modules to check.png
Mini is always dead.....
Jonny-english is offline
post #18 of 21 (permalink) Old Dec 21st, 2017, 09:45 AM Thread Starter
Quoted: 55 Post(s)
Garage
some kinda unrelated good news on the mini! so my thinking that the supercharger pulley making the eml light come on was incorrect...... turns out that the crank pulley has broken! was at the garage having a 17% put on but when they took the belt off the crank pulley was broken! this explains the lack of power and stuff!! Anyway on the Orranje website, lightened crank pulley +2 and 5% alternator pulley. so hopefully once all fitted the car will run and drive again.... then its just a matter of fixing the ecu wiring issue, but at least it will be driveable!
post #19 of 21 (permalink) Old Dec 24th, 2017, 06:55 PM Thread Starter
Quoted: 55 Post(s)
Garage
Runs fine now the crank pulley is done!! Tis perfect... Just need to sort the obd issue now!
Sent from my SM-G935F using Tapatalk
post #20 of 21 (permalink) Old Dec 24th, 2018, 10:50 AM
Quoted: 12 Post(s)
Did you ever solve this issue?
richo7256 is offline
post #21 of 21 (permalink) Old Jan 5th, 2019, 08:53 PM Thread Starter
Quoted: 55 Post(s)
Garage
Hi there, unfortunately I haven't fixed this yet but I am desperate to! Literally do not know what to do now. Are you having a similar issue?
Valve cover port oil leak Andrew Rogers Second Generation MINI Tuning 0 Oct 28th, 2016 05:31 PM
R50 Wiring diagrams billybodger First Generation MINI Cooper 1 Aug 30th, 2016 07:06 AM
2008 Cooper D Wiring Loom - Reverse Switch wju182 Second Generation Faults & Fixes 2 Aug 5th, 2015 02:58 AM
Wiring USB port to cigarette lighter? darrencp First Generation MINI Cooper S 2 Mar 20th, 2015 04:54 PM
Problems installing heated seats retro fit wiring loom - Please help !!! aveze First Generation Interior & Ice 1 Nov 26th, 2012 09:28 PM
